4.10 gears or 17's with et streets???
Old Oct 28, 2013 | 09:27 AM
mej0914's Avatar
Default 4.10 gears or 17's with et streets???
Going to the track on November 10th to run the quarter for the first time. I have run the 1/8th mile with my 22's with 305/45/22 nitto 420's and had no problem hooking. Cut a 2.09 60ft time. My debate is should I spend the money on some stock 17 inch wheels and put some 295/45/17 ET Streets on it for the track or just go ahead and regear from 3.42s to 4.10s. I should see a .5 drop with the way shorter ET streets but if I can hook my 22's with 4.10s I think it might be the same difference. I want to do both but only got the money for one or the other. Will cost about the same either way. What do yall think?
Old Oct 28, 2013 | 10:19 AM
Bullhead00's Avatar
If the truck is your daily driver, keep in mind that the 4.10s will kill your highway mileage. I just went from 3.73s to 4.10s and noticed a significant drop in mileage. However, my truck isn't my daily so I didn't care. My off the line performance did improve drastically though.
Old Oct 28, 2013 | 11:42 AM
mej0914's Avatar
Yea I read that I should be okay with the six speed. It does pretty good on the highway for being a big truck. Also when I finally get a blower on top it will bring back a couple mpg on the highway.
Old Oct 28, 2013 | 12:18 PM
ZO6Ted's Avatar
Don't think the 4.10s would hurt since you're 6 speed but I would definitely do the 17s. The rotational mass alone (and traction) not even counting the tire diameter would make a huge difference from the heavy 22s. Combined with a shorter tire it is a win-win. Also you're not burning up your street tires which I am sure they don't give away for pennies. Nice ride!
Old Oct 29, 2013 | 03:01 PM
mej0914's Avatar
Thanks bud. I picked up some stock 17's yesterday and ordered some ET Streets today. Ready to throw them on the rig!
Old Oct 29, 2013 | 05:13 PM
Vortec350ss's Avatar
It's gonna feel awesome! between the shorter height, huge weight loss, and more concentrated weight this is going to make a world of a difference.
Old Oct 29, 2013 | 07:10 PM
mej0914's Avatar
That's what I like to hear! Going to take everything off the truck that I can for raceday. Hopefully I can get it down to 5000lb. Hoping to run a 12.8. Never run the quarter mile before.
Old Oct 31, 2013 | 11:52 AM
Is the only change going to be the tires? That's a lot of time to make up with that swap alone... but based on the parts listed in your sig I wouldnt think its out of the question at all. I know you'll need a huge improvement on your previous 60'. I don't think you'll hit those times without hitting a 1.7x 60'
Old Oct 31, 2013 | 12:45 PM
mej0914's Avatar
Yeah. I know that gettin into the 12's is pushing it but with the cooler air then last time I went to the track, 5 inch shorter tire, 300lbs lighter im thinking I should get close. Gonna have to be running strong for sure.
Old Oct 31, 2013 | 01:52 PM
gamble686's Avatar
I figure it this way. For every 25lbs your wheel/tire combo loses you will pick up a tenth in the 1/4. That's only 6.25lbs per wheel. In addition for every 100lbs of body weight your truck loses you will pick up a tenth. So 300lbs 3 tenths and 50lbs from the wheels and tires should net another 2 tenths so you might drop 3-5 tenths from weight loss.
