4.00" bore head gasket options?
Old Oct 25, 2005 | 09:15 PM
BigKID's Avatar
Thanks for the info Whitt. I didn't find a thickness on the 9199 during my search today.
Old Oct 25, 2005 | 09:28 PM
BigTex's Avatar
Not quite BigKid, its somewhat the opposite. You'd have a tighter quench which increases combustion efficiency and fights off detonation. Personally, I'd rather have that .043 gasket than a .060 for that reason.
Old Oct 25, 2005 | 09:39 PM
BigKID's Avatar
Quench is the reason I was looking for a thinner gasket in the first place. I have just read that the overbore of the gasket may hurt as much as the reduced thickness helps.
Old Oct 26, 2005 | 06:36 AM
I needed the thicker head gasket because of the deck height of the pistons on my stroker,I doubt that would be an issue with a LQ4 block.
Old Oct 26, 2005 | 01:03 PM
Keith's Avatar
So you had a positive deck height with your stroker?
Old Oct 26, 2005 | 10:36 PM
blacksheep's Avatar
Go with the mls, my felpro's didnt last a week
Old Oct 27, 2005 | 08:19 AM
BigKID's Avatar
I am probablly going to go with the Cometic 4.00"/.040 gaskets. The are a little pricy but will be worth it if/when I pull the heads off again. Plus the quench on those will be much mo nicer.
thunder550
Oct 8, 2015 04:53 PM
DrX
Aug 19, 2015 04:45 PM
JordanH
Aug 8, 2015 07:59 PM
BIGD4504
Jul 28, 2015 11:46 AM
