4* cam advance, HELL YEA!!!!!!!
Old Sep 26, 2004 | 08:16 AM
Originally Posted by RED2K
Did you have to buy a after market timing chain set to be able to advance it? can you advance it with a stock chain set up
Yes you can advance your cam with the stock timing chain. Each tooth you advance the cam on the crank is 4*. Each tooth you advance the cam its self is 1/4* i believe. So degreeing a cam is pretty easy overall.
Simular to the subject, if you have a cam that is too big you can advance it and lower the powerband. If the cam is too small you can retard it to gain some power up high. I am thinking about retarding the cam in my Blazer to get some topend out of it.
Old Sep 26, 2004 | 09:09 AM
Flyer's Avatar
Advancing the cam is turning it clockwise??
Old Sep 26, 2004 | 09:26 AM
clockwise as you face the engine is advance.
Old Sep 26, 2004 | 09:48 AM
Sport Side's Avatar
Here's some help to this topic.
Big Tex wrote:
If you have too much exhaust duration for your setup hurting your torque, advancing the cam will just add to the problem.
He is speaking of how you are closing the valves sooner.
Look thru this thread if you haven't already.
Camshaft-advancing
OHsixLS3
Aug 10, 2015 07:19 PM
noproblems209
Aug 10, 2015 06:57 PM
Hmguyton
Aug 9, 2015 05:38 PM
JordanH
Aug 8, 2015 07:59 PM
