383 starts and dies
Old Feb 10, 2013 | 06:15 PM
  #21
greasemykey's Avatar
i might swap them in a second. gas was pumped out after i blew it up. i needed gas for my street bike and was low on cash. i replaced it 2 weeks ago.
map sits right behind the fuel rail cross over
Old Feb 10, 2013 | 07:36 PM
  #22
wish i could just call wheatley and have him confirm my tune just to double check.
Old Feb 10, 2013 | 11:21 PM
  #23
well apparently a safe tune requires a map and a maf
Old Feb 10, 2013 | 11:36 PM
  #24
AKlowriderZ71's Avatar
11 Second Hall Moniter
Well, the PCM needs a way to measure airflow to properly control fueling.
Old Feb 10, 2013 | 11:37 PM
  #25
oakley6575's Avatar
What exactly do you mean?
Old Feb 11, 2013 | 08:31 AM
  #26
TXSZ66AVLANCHE's Avatar
Bottom line a DBC system will not run without a MAF.
Old Feb 11, 2013 | 09:41 AM
  #27
Phantom's Avatar
11 Second Club
Originally Posted by txsz66avlanche
bottom line a dbc system will not run without a maf.
wut???
Old Feb 11, 2013 | 09:46 AM
  #28
Originally Posted by Phantom
wut???
Without tuning the MAF out the engine will start but immediatly stall.
Old Feb 11, 2013 | 10:28 AM
  #29
swift700's Avatar
My old setup ran with the MAF unplugged. It ran, but not so well. When the MAF information is missing, the PCM reverts to the engine airflow tables as discussed earlier. Now if these tables are not correct, the engine will not run.
Speed density tunes require no MAF. The computer is using hard airflow tables that are tweaked based on temperature and pressure (MAP sensor).
A non-speed density tune also uses these tables during transient operations such as acceleration where the MAF cannot provide enough information due to rapid changes.
The moral is: the airflow tables must be suitable for the actual air coming in or you will have an engine that idles poorly, stumbles or dies.
All of the above is referring to air. There may be a problem with fuelling as well, and it's a whole other can of worms. And there is also spark, but in general it shouldn't affect idle to a huge degree.
Old Feb 11, 2013 | 04:26 PM
  #30
oakley6575's Avatar
Why do you say that?
