350 rwhp?
Old Dec 11, 2005 | 03:21 PM
litreddevil's Avatar
Banned
i made 338 @ the wheels justin with the black gmc made 340. all with 5.3 no heads
Old Dec 11, 2005 | 03:27 PM
4.8 Liter Of Cola's Avatar
Originally Posted by PappyDan
4.8 pistons to raise compression
2002 LS6 camshaft 555 / 551 lift
LS6 heads for larger valves and better flow.
would those fit a 4.8?
Old Dec 11, 2005 | 03:53 PM
PappyDan's Avatar
Tribe Shaman
sure will
Old Dec 11, 2005 | 04:23 PM
tdrumm's Avatar
Do 4.8 pistons have the same compression height as a 5.3 piston? Is the rod length the same from a 4.8 to a 5.3? Pistons from a L33 5.3 are another possible solution.
Unless you mill the LS6 heads, you'll lose compression on a 5.3.
Old Dec 11, 2005 | 04:33 PM
14 Second Truck Club
4.8 pistons will not raise compression in a 5.3. They are the same motors, the only thing different is the stroke. The heads are the same too, just different numbers.
Old Dec 11, 2005 | 04:53 PM
joshluther's Avatar
4.8 pistons are flat tops and 5.3 are dish.
Old Dec 11, 2005 | 05:08 PM
mattrem's Avatar
The 4.8 uses a longer rod, not sure on the length, 6.285 I think
Old Dec 11, 2005 | 07:08 PM
joshluther's Avatar
The 4.8 pistons will "bolt" in to the 5.3
Old Dec 11, 2005 | 07:16 PM
Desert Reaper 5.3's Avatar
So about the L/T headers, will Thorley work, or is that the wrong choice. Let me know.
Old Dec 11, 2005 | 07:40 PM
tdrumm's Avatar
So the compression height is the same? It must be the longer rod that makes up the difference in stroke then. Good to know.
hodge9386
Oct 25, 2015 01:26 PM
wickedRCSB
Oct 10, 2015 09:29 PM
gmcyukon
Oct 3, 2015 11:03 PM
Wolftrk99
Oct 2, 2015 08:17 AM
cousblake11
Sep 9, 2015 06:52 PM
