34" Radiator bolt in replacement for 28"???
Old Jan 1, 2006 | 07:50 AM
JimS's Avatar
Default 34" Radiator bolt in replacement for 28"???
I have a 2002 Silverado w/a 28" radiator and want to replace it with a 34" when I put in the e fan. I believe it bolts right in. Correct?
Old Jan 1, 2006 | 08:19 AM
KySilverado's Avatar
No modification, completly easy, direct bolt in. You will need a couple extra bolts cause the fan shroud will now bolt in where the 28" rad did.
Old Jan 1, 2006 | 03:10 PM
Bigwake03's Avatar
Yea hes right make sure you get the bolts....umm Autozone and advance don't carry it....I had to go with a close second from napa...anyways if you can make you way to the salvage yard...just ****** some off any 99+up chev truck
Old Jan 1, 2006 | 06:35 PM
thunder550's Avatar
High on diesel fumes
Dealer should have them too, like $6 for the pair I think. Or $6 each. I forget.
Old Jan 1, 2006 | 06:50 PM
MonteCarlo31's Avatar
That'll be a great mod. To be honist, I purchased this 06 with E fans and was worried to death about them. Normally 10 to 13 miles of my afternoon commute is bumper to bumper on the highway. The first day I was in traffic I watched the temp guage like a hawk with the a/c cranked just to see. It did not move. It also feels much better taking off, no power draw from the fan spinning to cool the engine. It should also be noted, the vehicle also warms up much faster. I'm sold on e fans.
Old Jan 2, 2006 | 08:50 AM
JimS's Avatar
Anyone have any idea what a new radiator sells for? Ballpark guess?
Old Jan 2, 2006 | 09:20 AM
TG02Z71's Avatar
I might be talking out my *** on this but doesn't the bigger 34" raditor need more hood clearance?? Like the HD hood??
Just thought I remembered hearing that on the site.
-Tim
Old Jan 2, 2006 | 10:06 AM
thunder550's Avatar
I got mine for right around 300 I think, from Performance Radiator
thunder550's Avatar
-Tim
Negative, height is the exact same as the 27 incher. there are already bolt holes in the radiator support bracket too for the wider one. Direct bolt-in swap, very easy to do.
Old Jan 2, 2006 | 02:00 PM
Bigwake03's Avatar
radiatorbarn.com $255.00 with free shipping.
