317s vs 243s
Old Feb 16, 2009 | 03:08 PM
teamblackandred's Avatar
Default 317s vs 243s
looking to see if anyone has had reasonable gains on a lq4 from putting the243s on. any info would great thanks justin
Old Feb 16, 2009 | 03:17 PM
Mangled03gmc's Avatar
Baltimore Whore
If you plan to keep it NA, or run it with nitrous, the 243's are a decent upgrade over the 317's...
Old Feb 16, 2009 | 03:21 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
------because they will raise your compression ratio quite a bit, they have 64cc chambers as opposed the larger 317's.
Old Feb 16, 2009 | 03:23 PM
Baltimore Whore
Thanks coach HAHAHAHA
This is true
Old Feb 16, 2009 | 03:32 PM
do u happen to know what the compresion ratio will be.
Old Feb 16, 2009 | 03:37 PM
trever1t's Avatar
you will lose ~6.5cc's..there is a formula on here somewhere....see if you can find it
Old Feb 16, 2009 | 03:51 PM
thank you guys so 4 my set up it would be worth it then. just to get it out there my set up is lq4 .226/.226 ,3800 conv. 4.10s and 42lbs inj. and 200 wet shot thanks 4 the replies
Old Feb 16, 2009 | 04:20 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Can't you just mill the heads to raise the comp up instead of buying new heads since they flow the same?
Old Feb 16, 2009 | 05:22 PM
dlt76028's Avatar
exactly. or what i would do is put some ported 243 on their then you'll see a huge increase in hp and tq
Old Feb 16, 2009 | 07:44 PM
GMCtrk's Avatar
the 243s flow about 5-6cfm more up top. Also, milling the heads reduces your PTV, so if one ever decides to go with a bigger cam its probably best to stay with the 243s. 243s on an Lq4 should yield 10.6:1
