3'' Duals on 6.0
Old Nov 16, 2006 | 07:26 PM
dirt track racer 81's Avatar
Default 3'' Duals on 6.0
just wondering whats everyone's opinion would be with 3'' duals on my 6.0..i've already made some mufflers that will slide onto 3'' pipe..also when i had to pull my tranny i had cut alot of the pipe out, and i would have to redo it anyways..
Old Nov 16, 2006 | 07:37 PM
1SlowHoe's Avatar
Destroyer of Transmissions
It would probably be overkill. I did dual 2.5" with my LT's and I'm running 7-10 pounds of boost. I'd be worried about losing some bottom end power power. I'm sure it would sound good
Old Nov 16, 2006 | 07:41 PM
i know its probably overkill, i like the mufflers i got now, sound really good at wot, but i cant hear the cam as well as i would like, my friend a made a bullet style muffler for his camaro and his 232 237 cam sounds nasty..so i made the same kind of mufflers for my truck...
Old Nov 17, 2006 | 12:08 AM
thunderwagen's Avatar
I am running lt's and a true dual 3" and while it sounds good it is loud as hell. I am switching over to some bigger mufflers to try and quiet it down. But like 1slowhoe I am also boosted.
Old Nov 17, 2006 | 05:45 AM
Quik's Avatar
5 year bitches!
you have 364 cubic inches, most LS1s run dual 3" into a single 3" or into a single 4" and they make great power....i know im going dual 3" for the new setup
Old Nov 17, 2006 | 07:23 AM
bluecajun5.3's Avatar
11 Second Truck Club
i was about to say the same thing as quik did.
Old Nov 20, 2006 | 12:35 AM
NORCAL TBSS's Avatar
Restricted User
On my tbss i have long tubes with custom dual 3 inch pipes going to a single in/out magnaflow. im now changing to the dual 3 inch in/out magnaflow which has a internal x pipe and then dual 3 inch all the way to the back.
heres what it sounds like with the single entry/exit magnaflow
Old Nov 20, 2006 | 01:06 PM
Phantom's Avatar
11 Second Club
Old Nov 20, 2006 | 01:45 PM
jakebdb56's Avatar
Originally Posted by DozerDan
i wish I coulda unloaded that kinda cash for my exhaust.
as for myself the pacesetter 3" ORY into a 3" single out is perfect. I'm running cats too. as of right now I took the muffler off b/c the super 40 was kinda quieter than I wanted and I daily drive the truck with the exhaust dumped under the cab with the lt's and ORY and cats. it isn't annoying unless I cruise at 2200rpms then I go deaf b/c of drone
Old Nov 20, 2006 | 07:25 PM
Stoichiometric's Avatar
I think dual 3" is overkill, but nothing wrong with overkill. Expecially if you already have the mufflers. I ran dual 3" through the cats, then 3x2.5" reducers and a 2.5x3.5" Y and 3.5" muffler. I was going to run dual 3" but decided to use one muffler to keep costs down on my daily driver. I think the most likely culprit for torque loss is running the X pipe too far back, ceramic cats, or very poor collectors on the headers. I don't know for sure because my exhaust is way oversized
