3" Duals
Old Jan 9, 2009 | 02:36 PM
  #21
Llaverito's Avatar
Originally Posted by regency
do you know where in might find some video clips of a 4" exhaust
Here's my setup
https://www.performancetrucks.net/fo...d.php?t=418428
  #22
TXsilverado's Avatar
Originally Posted by GMCtrk
Well I think the answer is pretty simple. If you are after the fastest track times, 3" is the obvious answer. My personal preference is to 2.5" pipe. Gives more kick down low.
i disagree. single seems to be the answer IMO. the trick to getting good track times is getting it going fast down low because once you get going fast your pushing a heavy brick
Old Jan 9, 2009 | 02:39 PM
  #23
wayfastwhitie86's Avatar
Highly recomend a stall around 3200 to 3600. When we first got the cam in I had problems keepin it runnin at red lights lol but after nelson did his s/d tune the idle was fixed and it really came alive. Huge difference in power, awsome! I wouldnt step down a size at all on a 6.0l. I just bought a 3200 stall and I cant wait to get it in. But with the stock stall it takes a second for the power to kick in but when it dose you better have good traction cause it lights up my 295-45-20 up easy. So far the cam has been in for about a month 1/2, you will really enjoy it
Old Jan 9, 2009 | 02:43 PM
  #24
Originally Posted by skyhighsami
See mine isn't really 3 inch inlet it is whatever matches the stock diameter the best. The muffler is a 2 1/2 inlet and outlet muffler and the inlet side is opened to match the stock size piping and the outlet is just standard 2 1/2. I think removing the cats is what ulimately what killed the bottom end the most
Long tubes will fix that problem
+1
OH those dyno numbers where b4 cam, pulleys, and live tune
Old Jan 9, 2009 | 03:15 PM
  #25
cttandy's Avatar
I changed from a single 3 inch exhaust to a true dual 2.5' in/out 2.25" with a single muffler. 2.25" was the biggest we could get over the rear axle with the lowering kit. After reading flow charts, there wasn't a huge difference from 2.25/2.5 diameters, at least not while running dual exhaust. I have notice peak pulling power moved from 5500 rpm, down to a more usable 4500 rpm. After I raise the truck back to stock hieght, I possibly will change the tailpipes to 2.5" to see what effect that might have.
Old Jan 9, 2009 | 04:31 PM
  #26
Tell me more about the 228r idle and driveability. That's the same exact cam I have sitting here waiting to go in the 6.0 and I'm wondering if maybe I should step down in size. Thanks
ill send you my 226r for your 228r
Lthompson
Dec 22, 2015 06:14 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
sTNT971
Sep 26, 2015 04:22 PM
12secSS
Sep 16, 2015 03:59 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
