3 custom Cam selection.
1. 215/218 .545/.555 on a 112 LSA
2. 208/221 .530/.560 on a 112 LSA
Going in a '05, RCSB, 5.3, G80, w/ 3.73's, Towing package, K&N FIPK.
Truck is Daily Driven mostly Highway to work, but does tow my autocross car to events! So I need that good low-end torq & smaller stall.
Truck will be getting:
new springs and pushrods of course!
Pacesetter Long Tubes
Ory
Magnaflow.
Tuning
2600 Yank (I tow once a month)
Vette Servo's
Larger Trans Cooler
-anything else from Oregon Performance?
I'm leaning towards Cam #1. It's real close to the Comp XR 265 (a proven Cam), however, Cam #2 looks like a great cam as well, I'm just not very familiar with those specs as far as performance. Why these cams? Because they are available and certainly different! And, which one will be better down the road for a Maggie?
Thoughts?
-Joel
Ory
Magnaflow.
Tuning
Vette Servo's
Larger Trans Cooler
Thoughts?
-Joel
this is what im going with
DUR @ .004" 272* / 280*
DUR @ .050" 210*/ 218*
LIFT .531/.531
OVERLAP 48*
LSA 114*
POWER RANGE 1700 TO 6000
PROVIDES HIGH TORQUE, MODERATE LIFT, LONG VALVE SPRING LIFE
LIGHT CHOPPY IDLE
LIFT .531/.531
OVERLAP 48*
LSA 114*
LIGHT CHOPPY IDLE
Surely, the 4.10 help with getting your rig moving. You don't have issues with the "larger than recomended" Stall? And why again for the Split Duration cam? What does that get, more torque? I love the way the 220/220 112 LSA sounds in a 5.3. Are you hinting that I should go with the 220/220?
Do you think it will tow with my 3.73 gearing (9,500 lbs towing)?
I would go with the second choice for a radix on a 114 or higher lsa. The LPE GT2-3 is something like 207/221 on a 117 and is a very big hit the radix crowd.
300HP / 325Torque?
-joel
