3.7 liter I5 questions
Old Aug 13, 2006 | 05:01 PM
v8
17,16,15,14,13,12,11 Drvr
well if they do decide to build one, my truck will be back to stock and a new colorado ss will be in the driveway lol.
Old Aug 13, 2006 | 05:29 PM
nightrunner's Avatar
Mr. Obvious
and i will have one also however
GM will never build it. its against their "we cant build anything high performance because it might actually compete with the corvette or there isnt a market for high performance" rule
Old Aug 13, 2006 | 05:46 PM
I5M5's Avatar
I had a 3.5L/5-speed regular cab power nothing truck that was just an absolute blast to drive. I would put it up against a stock 5.3 silverado anyday. The big issue was traction, coming off the clutch meant wheel hop and big time. Counldn't make a 1-2 shift at WOT for all the wheel hop. There was a ZQ8 version that ran consistant mid 9's in the 1/8th mile. www.coloradofans.com is a good website for the colorados
Old Aug 13, 2006 | 06:17 PM
v8
a rcsb colorado I5 against a rcsb silverado 5.3, would be about the same times stock for stock. who ever gets the best light would win.
Old Aug 13, 2006 | 06:38 PM
Yelo's Avatar
As long as your not just pulling that out of your *** that pretty much sells me on the Colorado....I can handle that kind of power, that's pretty decent actually for a 5 cyl
Old Aug 13, 2006 | 06:42 PM
Mr. Obvious
good luck finding supporting mods for it as in boltons
unless i just wasnt looking in the right places, i couldnt find much a couple of months ago when i was comtemplating getting one
Old Aug 13, 2006 | 06:50 PM
Yelo's Avatar
I'll be going strictly turbocharged....as long as I can find larger injectors and HPTuners supports it within the next 6 months I'll be golden. I'll fab up a header if I have to but I'd rather use the stock manifold if I can for now
Old Aug 13, 2006 | 07:24 PM
Mr. Obvious
how many psi are you planning on runnin
you're doing this on a stock cam hmmmm
i want to see results
keep us posted on progress
Old Aug 13, 2006 | 08:15 PM
Yelo's Avatar
Max 10-12psi, and yes, I'll be using the stock cams to start out with....I'll probably run a meth setup as well just as a precaution
Old Aug 13, 2006 | 09:19 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Do they have cams yet for the I-6? If so maybe a machine shop could cut off the lobes for the back cylinder. Just a thought.
