3/4 ton radiator q's
Old Jul 10, 2003 | 04:26 PM
Hit Man X's Avatar
Default 3/4 ton radiator q's
I have been notice many people installing these in the 1/2 ton trucks. I figure I can easily score one as there is a late model truck junkyard local to me!
Do I need a 1500HD/2500/2500HD rad?
What all is entailed in this install?
Any temp drops with just the rad swap as the core is larger?
Thanks!
Old Jul 10, 2003 | 04:36 PM
parish8's Avatar
single digit dreamer
Default Re: 3/4 ton radiator q's
just the reg 2500 rad is all that people have been instaling. it bolts right in, all the hoses and lines work. you would need a diferent shroud if you still had the stock fan. this thing is huge, i was able to keep my truck at 172deg all the time, thats with atap. not sure what the stocker would have been able to do cause i did the fans and radiator at the same time.
Old Jul 10, 2003 | 04:51 PM
Hit Man X's Avatar
Is 172* with the stock thermo or lower temp one?
I am thinking that a 160* won't be too efficient as it will pretty much stay open in this Texas heat and the coolant in the radiator won't cool off.
So I am plotting a 180* thermo and that big *** radiator. I have taken that stock flyswatter off the truck a while ago, so now I have LS1 fans.
madmann26
Apr 29, 2020 09:17 AM
Vortec350ss
Jan 12, 2016 10:36 PM
cheyenne383
Nov 13, 2015 09:24 AM
Alco
Oct 4, 2015 06:58 AM
old motorhead
Sep 29, 2015 08:22 PM
