2500hd overheating
Old Jul 12, 2015 | 03:57 PM
ullose272's Avatar
Default 2500hd overheating
ive got a 2500hd with 05+efans that is overheating sometimes. its fine around town, but when i was on a road trip it was about 105 out and cruising at about 85 mph it would get up to about 235 with the a/c on pulling grades (anytime rpms were up really) i didnt notice this at all last summer. now we just picked up a camper the weighs about 6000 lbs and it will get hot 235-240 when pulling grades and it was only 75 out. i have a larger trans cooler as well and it stays about 125 until engine temp gets hot then it gets up to about 200.
i replaced the thermostat and the temp sensor. water pump is about a year or so old NAPA unit. only thing i can thing of really is maybe the radiator is plugged? or partially? i tow alot in the winter and never overheats but its also below freezing most of the time.
any ideas/suggestions? ive cleaned the fins of the radiator and condenser, deffinatly air traveling through. it will cool down if i pull over and idle for about 5 min but heats back up til im off the grade
Old Jul 12, 2015 | 04:18 PM
GMCtrk's Avatar
Sounds like a radiator problem to me, since it's doing it at speed.
It could be internally plugged up if you confirmed that the front is not full of debris/trash (they get like that over time).
The other considering is that your thermostat isn't working properly.
Old Jul 12, 2015 | 05:24 PM
ullose272's Avatar
ya first thought was thermostat, thats why i replaced it. and it was the original so i figured what the heck. but no dice.
Old Jul 12, 2015 | 05:26 PM
GMCtrk's Avatar
Water pump could be bad
Old Jul 12, 2015 | 09:54 PM
terravast4's Avatar
I have an 05 and every now and then mine runs hot. I popped the hood one day and found only one fan running...it only happens every once in a while though.
Old Jul 20, 2016 | 04:45 PM
txsilverc6's Avatar
any luck?
Old Jul 20, 2016 | 09:17 PM
FFDP's Avatar
After a whole year, I'd hope so lol.
Old Jul 23, 2016 | 05:55 AM
ullose272's Avatar
Originally Posted by txsilverc6
any luck?
I replaced the radiator with an aluminum one that is 1/4" thicker. But ive been deployed til now so ill probably know here soon. I think im going to throw on a flowcooler water pump and 160 tstat as well here soon.
Old Aug 5, 2016 | 02:05 PM
ullose272's Avatar
its no longer overheating
flatblack83
Jan 3, 2026 07:10 PM
BlownHD
Oct 3, 2015 12:24 PM
Cammed4ever
Sep 30, 2015 03:38 PM
69z-28
Sep 21, 2015 07:31 AM
zblee
Sep 17, 2015 07:58 AM
