243's
Old Jan 6, 2008 | 10:16 PM
Banned
Default 243's
i just got me a hold of some 243's with 918 springs in em already how much should i mill these for my 5.3 with stock head gasket and wat size pushrods will i need the cam that i have is a 224/224 .581 .581 112
Old Jan 7, 2008 | 07:13 AM
Gator's Avatar
If you mill them .035" your combustion chamber sz will be around 59CC, I used hardened stock length push rods but used .030" shims on the rocker arm pedestal bosses given me the correct lifter pre-load. ...The shim kit cam with .030" & .060" so you actualy could shim up to .090"....but if you wanted to just go with .025 shorter push rods you probably will be ok.....BUT it's always best to get a push rod lenght checker...
Old Jan 7, 2008 | 05:57 PM
Truckshop's Avatar
my 243's were milled .040 with a tr220 and i used 7.4 pushrods.
Old Jan 7, 2008 | 06:48 PM
low2001gmc's Avatar
nice heads you got there....buddy....
Old Jan 7, 2008 | 07:00 PM
joshua022's Avatar
My 243s were milled .055 and they measured out at 57cc.
Old Jan 7, 2008 | 08:55 PM
way2much_01's Avatar
I got the same heads and they weren't milled but they were surfaced the guy who did it didn't take much off he said not even .020
Old Jan 7, 2008 | 11:56 PM
20002wdchevy's Avatar
14 Second Truck Club
truckshop- did you use stock thickness head gaskets?
Old Jan 9, 2008 | 05:11 PM
Truckshop's Avatar
yes i did. stock 5.7 gaskets to be exact.
Old Jan 9, 2008 | 05:49 PM
Banned
so i would need 5.7 gaskets instead of 5.3 gaskets?
Old Jan 9, 2008 | 06:03 PM
Truckshop's Avatar
no i just had access to free gaskets so i used them!!
