243 or 821 or 823 for forged 6.0
Old Apr 19, 2022 | 07:21 PM
06murder's Avatar
Default 243 or 821 or 823 for forged 6.0
What would be the best head for a forged 6.0 it has summit pro ls pistons and rod in there flat tops, building nitrous engine!3-400 shot
Old Apr 19, 2022 | 08:54 PM
RDF1's Avatar
DuNnO
5 Year Member
832s and 831s make good power. Whats compression with the pistons you have?
Nitrous cam or N/A cam?
Old Apr 19, 2022 | 09:06 PM
06murder's Avatar
71cc =10.1 68cc= 10.4 65cc 10.8 61cc =11.5 2cc flat tops. trying to find a good nitrous cam i want max effort! lol goal is deep 6's in the 1/8th
Old Apr 20, 2022 | 05:43 AM
smokinlmm's Avatar
799/243 are the same castings as a corvette head with diffrent valves and such. I'd run the 243's, but the others aren't bad either.
Old Apr 20, 2022 | 07:55 AM
ALL ULL C's Avatar
I think a good rule of thumb and has been most likely documented someone in the www is that replacing a cathedral with a square port even with a drop in compression gains about 30hp, not sure it's 30whp. However I think that is more towards peak and not so sure what the entire curve looks like. Could always mill the square ports to gain some additional compression.
Old Apr 20, 2022 | 08:26 AM
68Formula's Avatar
Both 821s and 823s are square port. Only differences are the 823s chambers are 2cc smaller and hollow stem valves.
Old Apr 20, 2022 | 07:39 PM
smokinlmm's Avatar
If it's in a truck wouldn't the low rpm torque from the 243's help get it up and moving versus the square port higher rpm torque?
Old Apr 20, 2022 | 08:07 PM
RedXray's Avatar
100% Redneck
It would.
OP didn't post if the truck is going to live on the street. If it's a strip only truck a big stall will cover that low end handicap. A 300 to 400 shot is gonna have to be progressively controlled. Should pull like a freight train with either square or cathedral ports.
Old Apr 20, 2022 | 08:18 PM
06murder's Avatar
It’s daily for now till I get my wife car fixed, she driving my 16 Silverado right now, it will be street track only soon! It need a new converter right now I think the 5.3 with 200-250 over power it, it falling on it face right before the 1/8th! My cousin saying to run 821/823 on it it would help little on the spinning she does but gain more on top.? Cam I not set on yet tell I figure out the heads first nitrous will be on progressive 2 stages, just want low low 6’s to keep up at east coast truck wars
Old Apr 20, 2022 | 08:55 PM
01FormulaTA's Avatar
for your goals no question you run the rectangle port heads with a big converter to match whatever cam you choose
