241 heads on LQ9??
Old Nov 13, 2012 | 12:51 PM
nonnieselman's Avatar
but stock head for stock head.....
these are assumed to be stock, maybe milled flat for reuse.
Old Nov 13, 2012 | 01:34 PM
BigKID's Avatar
Stock for stock, the smaller combustion chamber of the 241 (66.5cc) raising the cr to ~10.8 is the only advantage of it over a 317. Factor in port work and that is a different story. I am currently running some mildly ported 241 on my truck.
Give the truck some fuel and fix the tune and it should run circles around a tuned 5.3 even with the less than optimal head/cam combo. Should have lots of low end torque with the ci, cr and small head.
Old Nov 13, 2012 | 02:53 PM
Waiting on a wideband..
i thought the 241s were the junk head.. i was mistaken.. i didnt know they were that close to the 243s..
Old Nov 13, 2012 | 02:57 PM
So this LQ9 should be ~10.8 CR with stock 241s?
Old Nov 13, 2012 | 08:30 PM
1FastBrick's Avatar
Custm2500's Rude Friend
A true LQ9 with flat top pistons is rated at 10:1 - 1 with 317
317 is around 72 CC
241 is around 64 cc
So Your going to be closer to 11.1 CR
If the heads are milled .010 to clean it up it could be more like 11:3-1 CR.
I have only had 2 Flat top piston motors apart and they averaged any were from .006-.008 above the deck.
The cam choice is not the greatest but with good tuning and fuel should still pull on that 5.3 with a cam.
HTH
Old Nov 14, 2012 | 08:38 AM
BigKID's Avatar
806 are the junk LS1 heads replaced by the 241 on LS1s in 99. IIRC 241 are 66cc and 243 are 64cc. 66cc is what I based the 10.8 cr off of.
Old Nov 14, 2012 | 08:51 AM
TXSZ66AVLANCHE's Avatar
I know guy in fort worth that has a LQ9, 241 heads, and a big donkey cam. Made 401 to the wheels this past summer.
FWIW another guy has a LS1, stock 243 heads, smaller cam. This combo made 422 to the wheels. Lol both tuned my same tuner that is pretty popular in the area.
Old Nov 14, 2012 | 09:13 AM
Ahh thats the head i was thinking about!!
Old Nov 14, 2012 | 01:23 PM
Found this today.. i thought the 241 head was smaller CC than 243?
Application GMPartNumber Combustion Chamber Volume (cc) Intake Port Volume (cc) Exhaust Port Volume (cc)
1997~1998 LS1 12559853 66.67 200 70
1999~2003 LS1 12564241 66.67 200 70
2001~2003 LS6 12564243 64.45 210 75
1999+ L59, LR4, 12559852/
LM4/LM7 12561706 61.15 200 70
1999~2000 LQ4 (Iron) 12561873 71.06 210 75
2001~2003 LQ4 (Alum) 12562317 71.06 210 75
2002~2003 LQ9 12572035 71.06 210 75
Old Nov 14, 2012 | 01:42 PM
No, 241 has bigger combustion chamber than 243.
