234 228 cam
Old Oct 28, 2003 | 08:31 AM
Banned
"fast"4.8 deleted my post cuz he can't handle the truth!!!!
Old Oct 28, 2003 | 11:46 AM
RED2K's Avatar
budget motors...gotta love'em. I have built a couple myself. {SBC stuff} Some of the best ones I have had were built this way. Good luck
Old Oct 28, 2003 | 03:58 PM
silent1's Avatar
Originally Posted by benpimpin1
I would put the fucken ls6 crank in because as of now the engine on my engine stand is a 4.8 which is the same block as the 5.3, which has the same stroke as the ls1. So you see why i would put in an ls6 crank. It is a higher quality and lighter than a stock 5.3 crank also.
Secondly what should kind of cam should I go for if I am to supercharge it?
You don't want a reverse split cam like the one you just mentioned for a supercharger application. I'd recommend something along the lines of a 212/218 or better yet a 216/220 525/532 114LS (especially since I have one for sale ). The second one I mentioned is one of the biggest cams I heard being run on a stock cubed 5.3, in case you are looking for the most out of your truck. Once you get into the 220+ cams you'll start running into clearance issues. If you are interested in the cam I have let me know and one more thing you should know is that you'll definitely need to change out your valve springs with just about any cam swap. Good luck on your project.
Old Oct 28, 2003 | 04:27 PM
Banned
clearance isn't an issue on a 226/226 .592/.592 cam, a good friend of mine is running the GTP piglet cam in his STOCK 99 5.3
Old Oct 28, 2003 | 04:40 PM
benpimpin1's Avatar
how does the truck run with that 226 cam? I have seen a package for the 5.3 that is around 234 227 with stage 2 heads I will have to check back to see who makes it.
Old Oct 28, 2003 | 04:47 PM
Banned
it runs good, idles like a top fueler and the low end flat sucks without gears or a converter. tuning is needed too, but ofcourse he hasn't had any
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
