212/218 with rockers?
Old Jan 1, 2004 | 12:27 PM
Flyer's Avatar
give it a few minutes ... I had to update my dynamic DNS crap .. it should work in a few.
Old Jan 1, 2004 | 12:28 PM
ThunderZ28's Avatar
12 Second Club
ok dookey
Old Jan 1, 2004 | 01:50 PM
954RR's Avatar
Originally Posted by 01 Thunder
hey 954RR is that the 114LSA or is it a 112LSA
FLYER what kind of a lope would i expect from that setup (212/218 522/529 114Lsa)
or can i get that in a 112 for more lope?
It is on a 114 LSA and I don't see too much of a lope from this cam at all unless you lower the idle down some. To get mine to idle right so it doesn't stumble when put into gear I had to raise the idle to 850. If anyone gets much lope out of this cam then they have it idleing at stock, or it is on a lower LSA.
So-- I wouldn't see much of a gain with these? Or even a sound change?
Old Jan 1, 2004 | 02:12 PM
I'm sure you'd gain about 10hp without losing any bottomend.I think I'd consider Yella Terras instead of SLPs.You'd probably need a smaller pulley on the Magnacharger to maintain your boost.What size pulley are you running?
Old Jan 1, 2004 | 02:32 PM
Sport Side's Avatar
would it be necessary to buy some rockers in place of the stock semi rollers if your plannin on installin a high lift cam anyways?
Old Jan 1, 2004 | 02:42 PM
954RR's Avatar
I am running a 2.90 right now. I lost about 1.5lbs of boost throught the cam install. Right now I see 7.5lbs at 4000 and a little over 8 at 6000. No KR at all.
Good tune thanks again to edit!
Old Jan 1, 2004 | 02:48 PM
No changing rockers is not necessary,but the Yella Terras are shaft mounted for more accurate timing and have a rollerized tip for less friction.They also come come in 1.7[stock] or 1.8 ratios.
Old Jan 1, 2004 | 02:51 PM
ThunderZ28's Avatar
12 Second Club
so the 114LSa will not give me any lope considering that i have the 1.85 comp rockers?
then i guess i will be going with the 112lsa.
can i get a 212/218 .522/.529 112Lsa ?
Old Jan 1, 2004 | 02:55 PM
99Silver6.0's Avatar
That cam will give some lope. I heard a few MP3's of that 212/218 and I have them onmy computer still. When its warmed up, it has a nce lope to it!
Old Jan 1, 2004 | 02:56 PM
954RR's Avatar
Well you will get a lope but it is not going to be a monster no vacuum making pig! Even with this cam at idle you wont see much about 10 inches of vac so your brakes DO operate a little differently.
If I turn my idle down to stock it sounds really lopey! But to get it to not surge in gear I turned it up to 850. Plus with a 112 I would of lost a ton of boost so I went with the 114, more economical.
Yella terras huh? How much for a set? I want something like 1.85 but am not sure.
