212/218 522/529 114
Old 10-14-2004, 07:09 AM
FILE's Avatar
Default 212/218 522/529 114
This is a very popular cam and I know many people have it here. I was wondering at what rpm's are you all shifting with this cam. I am currently shifting at 6200 with this cam and it seems it is still pulling very hard. I was ceonsidering raising my shiftpoints maybe 6300-6400. What do you all think?
Old 10-14-2004, 09:38 AM
I'm shifting mine at 6200 too. I thought about bumping mine up as well, but I don't want to push it with the stock rods and bolts. Is anyone else shifting at higher rpms?
Old 10-14-2004, 09:43 AM
MOOBIES Moderator
Scream's Avatar
As soon as I got EDIT I bumped the shift points up to 6500rpm. Went from 15.2-15.3s to 14.7, and picked up about 3-4 mph. The cam really wakes up past 6k. And I did it on an otherwise stock motor.
EDIT: Just thought of something--when I got the 4.8 dyno'd with the 212/218, I had the HPPIII and 6200rpm limiter, and remember that the graph was still climbing strong at the rev limiter.
Sometimes I wish I'd have kept the 4.8 and built a tranny/rear instead and gotten into the 13s with it. My mph was definitely there, just needed traction.
Old 10-14-2004, 09:58 AM
FILE's Avatar
I am not afraid to rev my engine to 6400-6500 since I currently have 918's valve spring and TR hardened pushrods. I was just a little sketptical because according to comp cams this cam power range is from 1800-6000. Looks like i will bumping my shift shift points to about 6400. Anybody have any dynographs on this cam?
Old 10-14-2004, 09:59 AM
MOOBIES Moderator
Scream's Avatar
Originally Posted by Tiburon
I am not afraid to rev my engine to 6400-6500 since I currently have 918's valve spring and TR hardened pushrods. I was just a little sketptical because according to comp cams this cam power range is from 1800-6000. Anybody have any dynographs on this cam?
I'll have to scrounge mine up and post it. I don't have it scanned in unfortunately.
Old 10-14-2004, 10:25 AM
The comp cam recommended power range is for a 346 c.i. LS1. Since our motors are smaller, the power range is shifted up. At least this is my understanding from reading on this board.
Old 10-14-2004, 10:28 AM
FILE's Avatar
You bring up a good point. I have read something similar about this. Anybody want to shed some light into this.
Old 10-14-2004, 10:32 AM
marc_w's Avatar
That's pretty much how I understood it. Different durations are needed to get the same effects from different CID's...
My 210/218 seems to sign off around 6,000 in my 6.0...
Old 10-14-2004, 01:51 PM
Sport Side's Avatar
Also, some of your mods might assist in reving higher than Comp's advertised power range.
Old 10-14-2004, 02:11 PM
12sec.5.3's Avatar
I've got my shift points set at 6180/1-2, 6350/2-3, with the rev limit at 6600. I think mine might make more power higher also with the heads but maybe not. I'm going put it on the dyno wednesday at Futral's shop and see what we can do.
Quick Reply: 212/218 522/529 114
