203 t0 2009 cam.
Old Mar 1, 2011 | 12:28 PM
urdone's Avatar
If your truck is an 09 the sensor will already be in the cover, all you need is the gear with tab for cam sensor signal, and bolts for said gear...
In my original post I was referring to swapping an 09 cam into an 03, had it backwards sorry
Damn i knew it yester i was like becasue i already had bought the cam and is all new for 650 i was like i should just bought a cam for it.
Old Mar 1, 2011 | 12:31 PM
urdone's Avatar
Originally Posted by skoal bandit
i hope you are changing your lifters too! I think your truck has DOD lifters.
Even do my truck is not FLexFuel?
Old Mar 1, 2011 | 12:46 PM
Robert91RS's Avatar
You will still need a non VVT timing cover and I would recomend replacing the lifters and valley cover to fully delete the AFM as Skoal Bandit mentioned. AFM is not the same as flex fuel.
Old Mar 1, 2011 | 04:23 PM
budhayes3's Avatar
PT's Slowest Truck
There's a bunch of info in the Internal Engine Mod section about VVT and DOD delete, including lifter pn's etc. I believe that one of the threads was started by supercharged680 or something like that...
Texas5.3_1251
Mar 5, 2016 08:10 PM
JordanH
Nov 6, 2015 07:42 PM
JoshH
Sep 28, 2015 11:19 AM
sTNT971
Sep 26, 2015 04:22 PM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
