2010 Silverado 5.3L cam swap?
Old Mar 29, 2014 | 08:51 PM
Pray's Avatar
Thanks. I was planning on using the LS3 cover like in the TSP kit. The block off's were for added protection against a leak.
Old Mar 29, 2014 | 09:31 PM
Tootall's Avatar
The block offs are a must when deleting the DOD/AFM. If you don't, the truck will have less than 10lbs of oil pressure when starting up.
I've posted a few threads on doing a DOD delete, you might want to read up a little more before starting
Old Mar 30, 2014 | 01:33 PM
Pray's Avatar
Cool, thanks. I will search your threads and do some reading. I have done a ton of cam swaps but this is a new animal. Just so I am clear on your last post, just using the o-rings that come with the LS3 valley cover will not be enough. I still need to drill and tap in some allen sets to ensure no oil leaks.
Old Mar 30, 2014 | 10:24 PM
Tootall's Avatar
Negative, no drilling needed on anything.
Use the LS7 valley cover with the charcoal filter or the 4.8 valley cover. Yes the LS3 works as well.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
chevyl33
Aug 24, 2015 08:21 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
Moto733
Jul 12, 2015 10:25 PM
Aboss
Jul 9, 2015 10:28 AM
