2008 5.3 to 6.2 questions
Old May 23, 2017 | 08:32 PM
woodwalker's Avatar
Default 2008 5.3 to 6.2 questions
looking for some good info on doing this swap. What will work and what wont. Saw some posts on 2007 and older. Any help appreciated.
Old May 23, 2017 | 08:37 PM
FFDP's Avatar
Buy one, swap it, tune it and pray the 4L60e holds together.
There really is nothing else to it, they are basically a 100% direct swap. Minimal things like VVT can either be kept or removed/tuned out and same with the AFM/DoD stuff depending on where the 6.2 comes from and what year.
Old May 23, 2017 | 08:41 PM
woodwalker's Avatar
Thanks I have read some are changing the servo in the tranny to a corvette is the true?
Old May 23, 2017 | 08:45 PM
FFDP's Avatar
That can be helpful in gaining extra line pressure and firmer shifts but that won't make it any stronger. A stock 4L60e can barely handle stock power levels with abuse, add another 80hp and 100ftlb torque and it's pushing it even harder.
Old May 23, 2017 | 09:14 PM
woodwalker's Avatar
Thanks for the help. Think i may go this route found a 2008 mod. engine with 54k can always up grade tranny later.I may have more questions later. Thanks again
Old May 23, 2017 | 09:22 PM
ZO6Ted's Avatar
I've thought about buying a 08-13 to mod because I really like the 6 speed. I would want RCSB 4x4 but I guess I'd have to do a 6.2 swap as well. Do you have a favorite year on Sierra's? I just prefer the styling on these yrs over the Chevy.
Old May 23, 2017 | 09:48 PM
FFDP's Avatar
You'd want a 2010+ to make sure it has a 6L80e behind it from the factory on a 5.3 truck. A 4.8 work truck would only have the 4L60e still.
Old May 24, 2017 | 08:27 PM
woodwalker's Avatar
FFDP I bought this truck new in 2008 it has 89k on it and it is a 4X4. I guess it has the 4L60E. Where is a good place to get tuned. Dealer or send computer out?
Old May 24, 2017 | 09:02 PM
FFDP's Avatar
It would have to be custom tuned. Ideally some place that could tune it in person or depending on where you live maybe even someone from this forum that does tuning.
A dealership wouldn't do this type of thing.
Old May 24, 2017 | 09:27 PM
woodwalker's Avatar
Ok thanks again when i get closer prob need more info. I don't know much about this new model stuff. Always messed with non efi.
