2007 suburban 6.0 swap
Old Mar 21, 2016 | 11:48 AM
09burb60's Avatar
Registered User
just verifiying the vvt is working I am trying to figure out why its runs like crap when everything is hooked up properly
Old Mar 21, 2016 | 11:53 AM
Wolftrk99's Avatar
Do you have a scanner that will show data??
Old Jun 25, 2016 | 02:36 PM
2WDinSnow's Avatar
Banned
How many miles on the LY6?
I did the exact same swap and still feel like it's running sluggish so I think that's just how they are with the stock cam.
Although I did the plugs, wires and seafoamed my motor after I swapped and it woke up a little.
Also when I did my swap I used the ly6 injectors (wish I knew to keep my FF ones) and the truck would start and shut off until it was tuned because the new engine didn't have D.O.D. kinda strange your's ran without a tune.
Old Jun 25, 2016 | 03:38 PM
Wolftrk99's Avatar
Who tuned it and was it in person or mail order? I would imagine going from a 5.3 to a 6.0 the maf tables need to be tuned.... Along with changing the displacement so the ecm knows its feeding a bigger engine!!
Old Jul 15, 2016 | 11:19 PM
2500HD6YL's Avatar
Registered User
Default 6.0 6YL engine
Originally Posted by 09burb60
Just gkt done this swap and the 6.0 feels verry sluggish, i used the 6.0 l throttle body and crank sensors, and 5.3l injectors, its feels horrible any suggestions thanks
My 2007.5 2500HD has the 6YL engine, and yes she feels flat and sluggish on the bottom end, but wakes up and pulls strong about 3500 rpm to 5800.
While doing bolt ons that includes exhaust,intake and mild 93 octane tune it helped less than expected in a cure to help the weak low end power.
I am plan to do a VVT delete and a performance cam 212/224 551/551 LSA 114 with the supporting mods and custom dyno tune. I believe this will give the 6YL nice power 2000 to 6000.
Old Jul 16, 2016 | 10:28 AM
Fast355's Avatar
If memory serves me correctly all LY6s have the L92 based heads on it with the larger rectangular ports. It will definitely wake up with a cam change, but watch piston to valve clearance, especially if you start to tighten the LSA. The LY6 I pulled apart had flat top pistons with no valve reliefs.
Old Jul 16, 2016 | 11:05 AM
Wolftrk99's Avatar
The 6.2 pistons have valve reliefs the 6.0 pistons dont...
Old Jul 16, 2016 | 11:35 AM
2500HD6YL's Avatar
Registered User
Default Valve to Piston Clearance
Thanks for the heads up info on LY6 pistons being flat top with no reliefs.
When H&C is going to be done on a stock LY6, confirm that the upgrade cam
has no VTP issues.
Old Jul 16, 2016 | 11:47 AM
Wolftrk99's Avatar
Correct.... Good idea on any build, though...
Kerr
Feb 19, 2016 03:51 PM
Scain33
Feb 17, 2016 09:15 AM
hunterbohanan23
Feb 16, 2016 08:04 PM
GREENMILE
Feb 11, 2016 09:09 PM
alex226
Feb 10, 2016 11:02 AM
