2005 INtake change?
Old Jun 12, 2005 | 10:21 PM
Dub Silverado's Avatar
Default 2005 INtake change?
Im looking at intakes for a buddys 2005 yukon 4.8 and K&N only shows a part number for a air charge, but no FIPK. Also, AEM shows the same models as previos years. Whats the deal with that?
Old Jun 13, 2005 | 12:50 PM
They should be all the same from 99- now. Its always been like that, if you look at some intake set-ups it will have a different part # for the 5.3,4.8 and the 6.0 but there all the same.
Old Jun 13, 2005 | 01:28 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
In the trucks they are different for the 05 model cause the airbox is different on the suv's i thought they were the same.
Old Jun 13, 2005 | 03:08 PM
Tractionless's Avatar
I think the 05 use a different intake than the 99-04 models. The K&N part number for the 05 is 63-3050. Here is a link with a pic. http://www.knfilters.com/search/prod...x?Prod=63-3050
It looks alot different than the one on my truck.http://www.knfilters.com/search/prod...Prod=57-3021-1
Old Jun 13, 2005 | 03:10 PM
That is the same number i came up with for the 05 K&N, but when i look up the AEM intake, its the same as the 99-04 trucks. 218000
Old Jun 13, 2005 | 04:55 PM
It may be due to the 05 trucks having efans from the factory. Looks like the tube section is different from the one on my truck. Theres more room there without the fan shroud.
Old Jun 14, 2005 | 06:15 AM
thunderwagen's Avatar
The 05's have 34 inch radiators and efans which totally screws with the mounting positions on the FIPK. I found this out the hard way. I ended up pulling the overflow tank out of the way to get more room to work, and broke out the cutoff wheel to trim the heat shield so it would fit. Then I had to drill a new hole in the heat shield for the bottom mount, and the top mount wouldn't work at all. Other than that it works great.
I guess you could call it almost bolt on.
Old Jun 14, 2005 | 05:05 PM
David1500's Avatar
It seems like on my 2005 one of the radiator hoses is in the way of the intake tube, hince why it is flat and goes above it. I may be wrong but in doing research on a custom intake I dont think I would be able to come out from the throttle body parallel with the engine due to one of the radiator hoses being in the way...........I may be wrong though.........
Old Jun 15, 2005 | 02:02 PM
tacodell's Avatar
I used K&N part number 57-3023-1 for my '05 Tahoe 5.3L. K&N only lists the models up to '04 for it. It worked, but I had to trim a little off the mounting bracket for the e-fans. I just needed to do this to get the heatshield rubber spacer/mounting bolt in place.
I can't say I noticed a big increase in hp, but the MPG has gone up about 1.5 miles per gallon.
Old Jun 24, 2005 | 06:55 AM
Smoke T/A's Avatar
Hey i have the 63-3050 K&N kit. I recently bought it off ebay and decided not to install it. I'm Asking $230 shipped. LMK
Joe
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Denali08
Aug 9, 2015 04:34 PM
Ls3silverado
Jul 31, 2015 04:22 PM
