2002 goals
Please give good replies, no BS and OT stuff.
Question: What are your mod goals for this year and what E.T.'s are you hoping for later this year?
Let's see who can acheive them by years end.
Mod goals
-Bored 5.3 block to 350+ c.i (still deciding how big)
-LS1 crank/rods
-custom pistons
-218/218 563/563 112lsa cam (may change a little)
-stage 2 heads
-lighter wheels
-ET streets
-truck weight reduction, loose ~500lbs
-Convert to wet kit and spray 125 to 135 shot
-2600 to 3000 stall converter
-shift kit
Performance goals
-looking for 350 to 375 rwhp N/A 450 to 500 on gas
-low 13's ET posibly bumping 12's
<small>[ July 10, 2002, 11:03 PM: Message edited by: Fast4.8 ]</small>
Mod goals
-LS1 crank/rods
-custom pistons
-stage 2 heads
-lighter wheels
-ET streets
-shift kit
Performance goals
6.2L block
-Offset ground 6.0L crank
-6.125" H-beam rods with bearing spacers
-JE custom pistons HPC coated (thermal/oil)
Valley Head Service stage II LS6 heads
-decked .055"
-Ferera 2.08/1.60 valves
-Combustion chamber work for larger bore
-valve spring seats machined for 987 dual spring set
-Titanium retainers / locks
-Manley hardened pushrods
Upgraded fuel system
-30 lb/hr Lucas style injectors
-Relocated fuel tank / cell
-Aeromotive fuel pump
-Aeromotive bypassing regulator
Direct-port nitrous
-NOS digital progressive controller
-Jaz 3 gallon fuel cell
-AC delco 95 psi inline pump
-Magnaflow bypassing regulator
-Inline fuel cooler
Weight redux
-Bogart Drag-on II 16x4 front runners
-Bogart Drag-on II 16x10 rear wheels
-Hoosier 28x10.50x16 QTPs
-VFN 2" cowl fiberglass pin-on hood
Richard
-decked .055"
Direct-port nitrous
-Inline fuel cooler
Weight redux
Richard
mine aren't too complex:
install my 10" subs and amp (already purchased)
replace factory speakers
3" body lift (maybe a level kit as well)
305 or 315 tires (not sure of the width)
17" denali rims
UPD intake
HPP III w/thermo
black fender flares (not the plastic looking ones)
paint the bottom fog light bumper black
chrome "Z71" third brake light cover
that should hold me for awhile <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
17" denali rims
UPD intake
HPP III w/thermo
To be in the top 5 five of the Fastest Trucks.
I think I have a pretty good start http://www.ls1truck.com so a little more should get me there in no time. I plan to have:
4.10 gears
Posi
Fat tires
Performance Cam (not sure how radical yet)
100 HP Shot
I think I should be in the 14's somewhere, I raced a Probe GT and a V6 Camaro this week and beat them. Not much to go off of, but it made me feel good, they just looked and shook their head and smiled?
allen
<small>[ July 10, 2002, 09:55 PM: Message edited by: AllenSSilv ]</small>
4.10 gears
Posi
Fat tires
100 HP Shot
allen
Well I hope to get into the 14's. It shouldn't be too hard since the ex cabs w/ 3.73 locker are doing it stock. I have the money but am still looking for a good used 3.73 & locker for about $300 (thanks for the info last week oxidizr.) I am going to install a Vette servo probably tomorrow. If anyone has install instructions and/or pics send them to cashdudehomie@webtv.net I will also be getting the ASP crank pulley soon. I need to do the tstat mod ASAP but I can't find a damn BB!! Exterior, I will be getting the door and tailgate handles and mirror covers painted to match, and swap my Chevy molding for the GMC style. A roll pan and black chrome inside handles will be put on too before the end of the year.
1.UPD intake (on the way as we speek!)
2.160 thermostat
3.LT1-LS1 Fans (whichever i can git)
4.NGK TR55 plugs
5.Magnacore 8.5 wires
6.M-A-S
7.ASP Pully's
8.AS&M Long tube headders
9.Random tech cat's
10.Programer (cant decide which is best for me yet...hypertech,predator,LS1 Edit?)
11.Yank 2400 stall conv.
12.vette servo
13.trans shift kit.
14.slotted rotors,and better brake padds
15.Last but not least billette specialty 20x9.5 hustler 6 wheels and goodyear rubber <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
It may not be all that compared to what everybody else hs already done but once all this is completed, I will be satisfied! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
2.160 thermostat
4.NGK TR55 plugs
6.M-A-S
7.ASP Pully's
9.Random tech cat's
12.vette servo
13.trans shift kit.
Here is mine,
-New tranny, probably Jet, in the works right now. It will probably be in Street Trucks again on that.
-Ported throttle body with bump stop mod.
-Electric fans
-Torque Coverter, not sure which one yet. Have a trans cooler waiting.
-Dyno tuned, not sure where yet: raise shift points, remove TQM, ect.
-Maybe some ASM long tubes, not sure if the gains would be worth it though.
-Some sticker tires
That is all I can think of right now, do not want to get too extreme. I am hoping for some mid to high 13's before the tuning, and low 13's after.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> -Hoosier 28x10.50x16 QTPs </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey Oxidizr, does that mean you are going to sell your ET Streets? If so, you got a buyer.
-Electric fans
-Some sticker tires
I am planning on a converter and some tranny work along with some custome tunning (to get rid of the TQM). Hopefully I can be hitting the 13s N/A on stock internals when the weather cools off a bit. Then I will be looking into nitrous and maybe even a cam. I would get the spray now but I am scared my tranny wouldn't hold it. It is having a hard time as it is now.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BigKID:
<strong>I am planning on a converter and some tranny work along with some custome tunning (to get rid of the TQM). Hopefully I can be hitting the 13s N/A on stock internals when the weather cools off a bit. Then I will be looking into nitrous and maybe even a cam. I would get the spray now but I am scared my tranny wouldn't hold it. It is having a hard time as it is now.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey Kenny, man we have the same mods so far, and looks like we are planning the same things. My goals are identical to what you are planning. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
My baseline is a 15.73. I'd like to get into the 14's (and maybe someone can help me out if I'm going in the wrong direction) with:
--LT-1 electric fans (which will allow me to put the rest of the FIPK kit on)
--UD pullies
--50 or 75 shot NX kit
--3.73 gears/auburn locker
--ET Streets (or similar sticky tire)
Will it take more to get there? less? Thanks for the input.
<small>[ July 11, 2002, 12:08 PM: Message edited by: Scream ]</small>
--UD pullies
