2001 GMC C3 78mm dbw to NNBS 87mm help
Old Apr 2, 2016 | 09:32 PM
AlwaysOnKill's Avatar
Default 2001 GMC C3 78mm dbw to NNBS 87mm help
I'm working on a friends truck and I'm having some Tbss issues .
Truck is a 2001 gmc c3 with a 78mm dbw tb
We put on a Nnbs intake with 87mm dbw tb.
We used the casper ls6 to ls2 wing adapter .
I wired it up using diagram from here LS2 throttle body harness adapters
We had to swap the brown and yellow wires since the Tb motor was going to 100% with the key forward .
It idles correctly for a second then raises idle up and reduce power light comes on .
I'm at a loss . Help!
Old Apr 3, 2016 | 01:46 AM
Wolftrk99's Avatar
What codes is it throwing???
Old Dec 7, 2023 | 07:06 PM
CrisKyro's Avatar
Did you ever figure this out ? Or are we stick with the 78mm on the 01-02 dbw 2 connector set up?
Old Dec 9, 2023 | 09:32 AM
10 Second Club
The stock throttle body isn't as bad as everyone thinks. A friend of mine tested an LS3 gold blade on his swap. Then an adapter with the factory TB. They made exactly the same power. (422 rwhp)
Old Dec 9, 2023 | 09:40 AM
CrisKyro's Avatar
I believe it. I’ve come to the conclusion that the hp per dollar for an LS2/3 throttle body is not worth it for me. I really wish the 87mm gen 4 truck throttle body was more of a plug and play solution. Was he able to see or feel any power band differences with the adapter and 78mm?
Old Dec 9, 2023 | 10:52 AM
10 Second Club
The graphs when overlayed mirrored each other. He did say that the throttle response feels better with the 78mm TB. He ended up selling the LS3 TB and X link, and investing that money elsewhere. I worked on a local 5.3L truck, had all kinds of issues with the X link. Put the factory TB back on, made the exact same power and no drivability issues. Those are 2 instances I have personal experience with, as you said - the HP per dollar isn't very good.
Bob Bobert
Jul 8, 2019 11:16 PM
bottledls6
May 16, 2015 01:27 PM
NextLevel
Jan 26, 2012 11:24 AM
EasyE1986
Apr 21, 2011 02:57 PM
beingblueeyes
Apr 20, 2011 08:58 PM
