ls2 dbw TB
Old Jan 25, 2012 | 11:32 PM
NextLevel's Avatar
Default ls2 dbw TB
How do I go about running a 90mm ls2 dbw tb on my 2004 lm7 with stock dbw intake and stock dbw tb. Do I need an adapter?? What are some other stock tb's I can use? Do I need to just stick with the stock tb to not loose low end?
Old Jan 26, 2012 | 12:36 AM
1slowz71's Avatar
You would need a adapter plate and an x link but if ur gonna do all that might as well do a tbss intake manifold swap
Old Jan 26, 2012 | 05:23 AM
AndysC3's Avatar
Are you keeping the stock 3bolt intake, or upgrading to the TBSS/NNBS 4 blot intake? If your keeping the stock 3 bolt it wont be worth upgrading the TB to a 90mm LS2. The stock intake only has around an 80mm opening. Pick up a used TBSS/NNBS intake, swap it on, and have fun.
Old Jan 26, 2012 | 11:24 AM
oakley6575's Avatar
I agree with these guys. Go with a used tbss or it's not worth it. You will need an adaptor harness either way. torquerushperformance.com
natejk
Nov 15, 2016 08:05 AM
thewrx
Oct 6, 2015 10:59 AM
gmcyukon
Oct 5, 2015 06:20 AM
trxmxzx
Sep 29, 2015 07:42 AM
maxspeed05V
Sep 23, 2015 10:48 AM
