2000 Silverado 5.3 surges in OD at @40-50mph
About 2 months ago my 2000 5.3 Silverado started surging in OD between 40-50mph. I haven't been able to track down what would cause this. I have run FI cleaner through and it still happens. Any ideas out there???
No, I haven't had it scanned yet for codes. No one around the area does "free" scans. It acts like someone is lightly pressing the throttle and then letting up. The problem is it doesn't do it all the time so it is hard to put any pieces of the puzzle together. Of note I do have a Jet PowrShift on it, but I wouldn't think that would be causing the problem.
Originally Posted by cablebandit
sounds like the converter is slipping in/out of locking up a little
I just fixed my surging, exact same description as yours, on the scan tool you'll see the TCC locking and unlocking. The 4l80 has it's own speed sensor...input sensor was bad. Runs great now.
Originally Posted by dewmanshu
2K 5.3 with what mods? Is is a built tranny? 4wd? still have 4l60? Found yourself a good reason to buy a scan tool or have a local shop get what codes you are showing (I am sure you know not all codes have to throw a SES light). If you are showing an "Incorrect Correct Gear Ratio" code this means you either have a bad TCC solenoid or a bad speed sensor. Most likely the speed sensor? How many miles? Might be simple with the FI cleaner, but the PCM will throw a light for any emission related stuff, so it's probably not a good chance. I suggest getting any engine codes if there are any first to establish a game plan. Especially if you are stock. If your mod'ed, finding the issue might not be as easy.
17,16,15,14,13,12,11 Drvr
where do you live? Maybe someone from here has a scan tool to help you out. Next thing i would check is the chip you have on the trans disconnect it and go back to stock and see if the problem still there.
I live in San Angelo, TX. I'm going to try disconnecting the Powrshift and see what happens. As far as gas goes I'm in the military and buy 95% of my gas on base. I"ll keep all ya'll posted..... Thanks for all the help!!
