2" kooks fbody headers on a 2004 silverado??
Old Jun 11, 2012 | 08:17 PM
lablackbeast's Avatar
doesn't know what quit means
Default 2" kooks fbody headers on a 2004 silverado??
well was looking to buy some 2" kooks fbody headers, i know you can make them fit in truck but what all does it have to be done.?? thanks in advance, if yal have pics that will be even better
Old Jun 11, 2012 | 10:25 PM
kren7604's Avatar
I just tried some kooks 1 7/8 super competition LT's off of 02 T.A. Paseenger side went on perfect but driverside wouldnt fit, i even tried beating it in just a little to clear but it still rubbed, and wouldnt clear the engine crossmember..
Old Jun 11, 2012 | 10:46 PM
LS1TRUCKGUY's Avatar
pm txsilverado. he had some stepped 2" to 1 7/8" with 3.5" collectors. pretty sure he didnt do anything to make them fit
Old Jun 13, 2012 | 08:08 PM
1989k1500's Avatar
Dunno if this helps at all but Banker099 has or had a set of TSP f body headers on his, I believe they were 1 7/8. Maybe see if they sell a 2" set.
Old Jun 13, 2012 | 08:13 PM
ltr450ryder's Avatar
I have the tsp 1 7/8 headers on my 01 and the fit fine just got bend the Tranny lines so there out of the way
Old Jun 14, 2012 | 12:14 AM
Blown06's Avatar
8 Second Truck Club
2" F body kooks here. Driver side fit fine, passenger side hit the frame to the point it had to be notched. Also, had to cut the ears off the trans on both side. nothing to it.
Old Jun 14, 2012 | 04:39 PM
BigKID's Avatar
I have 1-7/8" to 2" Kooks f-body headers and my #6 primary tube barely touches the pass side frame which you can see in the following pic. You will also have to get creative with the y-pipe.
Old Jun 14, 2012 | 04:54 PM
TXsilverado's Avatar
what the hell kind of motor are you planning to need 2" headers for? i think you'll be fine with 1 7/8 headers. 1 7/8 stepped to 2" max. 1 7/8 will fit better due to the 3" collector. my stepped headers with a 3.5" collector was extremely close to the frame because it was 3.5 and i reduced it to 3" anyways.
Old Jun 14, 2012 | 08:37 PM
adrian_14nk's Avatar
Registered User
im also trying the tsp f body 1 7/8 myself but knowing roman he has something up his sleeve to push some hp out the 2 in headers but each to his own
Old Oct 6, 2012 | 06:16 PM
Guys since I am going to be running a procharger I am trying to keep the exhaust flow as much as I can so I can make as much power with less PSI ... so 2" hit the frame??
ARC
57
Feb 21, 2022 10:54 AM
wrb002
Aug 31, 2015 12:00 PM
Castro45
24
Jul 31, 2015 07:13 PM
KOOKS Headers
Jul 27, 2015 01:43 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
