2-3 shift hangs "help"
Old Nov 27, 2004 | 12:09 AM
Kano's Avatar
Default 2-3 shift hangs "help"
I think I got a problem with my transmission
when it shifts to 3rd it pauses for 1/2 sec to 1 sec
then shifts
It does this only sometimes
like at the track tonight
only thing I can think, is I had my tune set up for a stall
and aint got one yet and its acting up
or I messed up with the transgo
also at about 3/4 throttle it will bark the tires goin into 2
and wot barely chirp them
I dont know ,what yall think
Old Nov 27, 2004 | 04:54 AM
sfj
if you think it is because of the tune doesnt nelson offer free upgrades i would get him his module back and try without the stall tune to it and see if it helps any other than that i dont know good luck though
Old Nov 27, 2004 | 10:35 AM
BigKID's Avatar
Did it start doing this right after you installed the transgo?? Did you install the spacers in then 1-2 servo? If so your 2nd gear band is probablly not releasing quick enough on the 2-3 shift so both the band and 3rd clutch back and all enguaged at the same time.
As far as the barking at 3/4 and not at wot.. sounds like a tunning issue in the line pressure table to me. Your 3rd gear studder could be in the tunning as well depending on how Allen set up your shif speed tables and what he did with TQM.
Old Nov 27, 2004 | 10:53 AM
Kano's Avatar
right after the transgo and retune
no spacers, washers,holes drilled .82 on 2-3 none on 1-2 and .093 on the rest
I also didnt use the blue or orange spring
and i didnt put the clip thing in the screen
Old Nov 27, 2004 | 11:48 AM
Flyer's Avatar
The torque converter is locking as soon as it hits 3rd gear. Is this one of Allen's tunes?
Old Nov 27, 2004 | 12:19 PM
Kano's Avatar
yeah
I told him to set it up for a stall
locking as soon as it hits 3rd is that bad?
how much at the track you think Im losing?
Old Nov 27, 2004 | 01:58 PM
Flyer's Avatar
Not bad .. it takes a load off the 3/4 clutch pack and puts it on the converter clutch.
Maybe a couple tenths??? Hard to say.
Blwn99x
Mar 24, 2023 11:14 AM
RustyD
May 23, 2016 07:04 PM
Wolftrk99
Dec 3, 2015 08:12 PM
Wolftrk99
Oct 1, 2015 07:36 AM
sTNT971
Sep 26, 2015 06:27 AM
