160 thermostat
Don't spend the $50+ dollars on a hypertech. Just modify your stock one. It is very easy and works just as well. I have had mone running for several months with no problems.
Here goes:
Remove the t-stat from your truck (two 10mm bolts). Using pliers, press down and twist off the upper part of the t-stat. (Fig A) This will free up the assembly. The springs are pretty strong. (Fig B) The goal here is to make the t-stat open sooner (at a lower temp) so you need to add something to the small hole in the main housing that will force the t-stat to open sooner. I used a typical BB to do this. The "rod" (Fig C) that fits into the housing goes in about 1/4" So whatever you insert in there needs to be smaller than that. A BB worked fine and I didn't take the time to look any further for other items lying around. Reassemble the t-stat. Note: Be prepared for alot of coolant to flow out of the water pump when you remove the thermostat.
<img src="http://www.jade-co.com/tstat.jpg" alt=" - " />
Here goes:
Thanks for the mod Big Tex, how much did the BB lower the engine temp? ON my 5.3 is runs about 205-208 degrees or so on the temp gauge. I read somewhere that even with the 160 stat the engine is still around 180 degrees.
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Shotguntommy
Sep 15, 2015 05:24 AM
160, 2001, 2002, 2006, cost, h3, housing, hummer, ls1, putting, replacement, silverado, silveraldo, sizes, ss, texas, thermastat, thermostat
