160 therm any good or do you...
Old Mar 18, 2007 | 10:01 AM
ty02silv's Avatar
Default 160 therm any good or do you...
i'm new to the trucks into the lt1 camaros, but i know on the camaros if you put a 160 therm in you have a tune done to turn on your fans sooner. does it work that way with the 5.3 trucks or cant you turn the fans on sooner?
Old Mar 18, 2007 | 10:14 AM
nightrunner's Avatar
Mr. Obvious
you can but it doesnt rally help the gen 3 motors any they are made to run hotter than the gen 1 or 2 sbc, basically all it does for us is lose 1-2mpg
Old Mar 18, 2007 | 10:44 AM
bluecajun5.3's Avatar
11 Second Truck Club
humm...
well if they were made to run hotter, then why does my engine run alot faster at the track with a cooled down engine compared to when it's hot?
Old Mar 18, 2007 | 10:48 AM
Mr. Obvious
ok i'll say i have read this on this fourm on more than one occassion
im saying the gen3 motors are made to run a little warmer than the gen1 sbc
and more than one member reported no to little gains with the 160-degree tstat and lost 1-2 mpg, one memeber that sticks out it chevy6000vho
Old Mar 18, 2007 | 11:09 AM
truckmann's Avatar
I was thinking about doing the same thing, but a former employee of the GM R&D team that we all know around here informed me on what nightrunner is saying. I trust his input so I decided there was no reason for me to put in a 160 thermostat.
Old Mar 18, 2007 | 12:20 PM
Formulized94's Avatar
I will lose a mile or two per gallon to let the engine run a little cooler. Les heat keeps wear down also, it is proven....
Old Mar 18, 2007 | 12:35 PM
Quik's Avatar
5 year bitches!
not enough heat is harmful also
Old Mar 18, 2007 | 12:36 PM
Quik's Avatar
5 year bitches!
160 isnt worth it by no means unless you have a boosted motor or a large cubed motor which takes alot of timing.
our motors need to be above 178* to function properly
so for average person 180 is more then enough
Old Mar 18, 2007 | 12:44 PM
Derek @ EDO's Avatar
FormerVendor
your not going to run 160 with a 160 stat I have one and i run 178-180 right where i should be.
Old Mar 18, 2007 | 04:41 PM
exactly, oh well. This topic will always be biased to no end. If you want it buy it, if not dont. It seems maybe you should look for a 280 thermostat, it may run better then j/k
