160 t-stat or 180 t-stat
Old Mar 7, 2006 | 11:04 PM
1slowsilverado's Avatar
Oh yea AutoZone now carries the 160 and 180 stat now for around $30 with housing. its a duralast but works the same and is cheaper than a power stat.
Old Mar 7, 2006 | 11:07 PM
treyZ28's Avatar
When your block is cooler, it will wick away head from the cylinders faster and hence mpg loss.
Old Mar 7, 2006 | 11:46 PM
AintNoHo's Avatar
With my supercharger I have a 160* thermostat which makes the engine run at about 175*-180*. I have heard that when the PCM is not tuned for the lower temperature, the engine may run too rich thinking it's still in warm-up enrichment mode giving good throttle response but less milage.
Old Mar 8, 2006 | 12:16 AM
Yelo's Avatar
GM has designed these motors to run at ~195º for a reason......within reason engines function better the warmer they are (this is a proven scientific fact!!), The ONLY reason there ever was to go to a lower temp thermostat was when cast-iron heads were popular, cast-iron is a heat-sink and warms up VERY fast, to cool the chambers enough to prevent detonation on hi-po motors 160º thermostats became popular...now that aluminum is used almost exclusively for cylinder heads the 160º thermostat has become a pointless modification.....
Old Mar 8, 2006 | 06:37 AM
dewmanshu's Avatar
Moderately Differentiated
For NA.
Old Mar 8, 2006 | 06:51 AM
Whippled 496's Avatar
I guess thats why my big iron 8100 likes the 160* then.
Old Mar 8, 2006 | 08:50 PM
Pointless mod? I would like to see these "Sientific Facts".
Old Mar 8, 2006 | 09:26 PM
budhayes3's Avatar
PT's Slowest Truck
I'm happy with my 160* stat, but my PCM has been tuned accordingly. Great heat in the winter (actually comes up faster since the stat opens sooner allowing flow sooner), and my trans temps have decreased also. Efans are set to 180* on, 173* off.
Old Mar 8, 2006 | 09:31 PM
TURBHOE's Avatar
me too i found over on the tech that these engs perform better in the 170* range as far as mileage i would say tune it correctly and it should be ok i dunno i'll let you know.
Old Mar 10, 2006 | 09:28 PM
04blackvho's Avatar
went with 160 thats
