140,000 mile LS1 engine leak down results
Old Mar 3, 2010 | 07:54 AM
  #21
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I doubt its anything with the heads since they have very few miles on them.
Stewart put breathers on it and see what it does, if it stills burns oil without a PCV system then you know for sure its a problem with the shortblock.
Old Mar 3, 2010 | 08:53 AM
  #22
TXsilverado's Avatar
i spin alot of RPM. 7k most of the time. i figure most of my oil is being sucked into the intake. i really was surprised with the leak down results. i figured it had atleast 1 hurting cylinder. i think some new plugs and some breathers in the pcv and oil cap will get me on the road and running 100%. can't wait to get my new exhaust in. and the suspension done.
Old Mar 3, 2010 | 08:55 AM
  #23
Originally Posted by 454navyss
have you checked your pcv valve? valve seals or guides?
heads only have about 15k miles on them. the leakdown would have show if it had a bad valve seal/burnt valve. everything checked out 100%. these motors are incredible.
and for all of the royal purple haters:nunchuk1:
Old Mar 3, 2010 | 11:07 AM
  #24
dlt76028's Avatar
My old 6.0 was blowing the dipstick out and I did a compression test and they were 0-75. The engine was trash.
Old Mar 3, 2010 | 11:14 AM
  #25
zero is impossible...75% is horrible. are you sure that the valves were shut completely?
Old Mar 3, 2010 | 11:46 AM
  #26
dlt76028's Avatar
When I did it, I was getting ~75, when a local performance shop did it, they were getting 0. Anyway you look at it, the engine was bad, it was blowing the dipstick out and had lots of blow by coming from the oil filler.
Old Mar 3, 2010 | 11:51 AM
  #27
TIM Z's Avatar
11 sec. Truck Mod
Good to hear another GEN III motor holding up to abuse. these things are awesome.
Old Mar 3, 2010 | 11:59 AM
  #28
sixltrbtr's Avatar
I'd redo the leakdown to be sure.
Old Mar 3, 2010 | 12:10 PM
  #29
silver-mod-o's Avatar
Hunt&Fisherator
Bend those electrodes back down, slap em back in and give 'er hell!!!
Old Mar 3, 2010 | 12:29 PM
  #30
BlackGMC's Avatar
Resident Retard
if you gonna run breathers, you might want to check with your tuner about how the tune is setup... If you still running a MAF and trims (closed loop), basically a stock step-up tune, those breathers will allow unmetered air to come threw the intake track and cause your trims to max out, basically you would be creating a vacuum leak...
but if you just run breathers and cap off all lines going to the TB, intake, etc. you will be fine...
