108LSA cam running on stock tune
Old Jul 11, 2006 | 12:47 AM
  #21
Sport Side's Avatar
Originally Posted by LS1BirdDRG
I'll chime in since I was there helping on the install. Yes, we did prime it with coil packs unplugged.
That's very odd Kyle, since there was no tapping at all Sat. night when we took it for alittle test drive. Keep me posted.
Hard to hear with the windows down. It's faint but, with the windows up you can hear a tapping all the way down to idle and it does increase with RPM.
Old Jul 11, 2006 | 10:18 AM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Check your rockers again they can cause "lifter hop" if they have backed off. On a few cam installs I have had to do that. Pull the rockers back off clean the threads throw a little red loc tite on there tighten them back down spin the motor over tighten them again and call it good.
Old Jul 11, 2006 | 12:10 PM
  #23
bluecajun5.3's Avatar
11 Second Truck Club
Originally Posted by FarmerBeau
Kyle, ask Ed what base-circle he uses on his blanks.
one other thing. once you threaded the rocker arm bolts by hand, how many turns did it take to torque them down with the torque wrench.
harrison's cam with the 7.4" pushrods took too many turns, somewhere's like 4 i think. then switched to the 7.35" and they came in to spec. i think it's only suppose to be 1/2 to full turn to 22ft lbs.
Old Jul 11, 2006 | 05:26 PM
  #24
moregrip's Avatar
what a rush!
how'd the tuning go?
Old Jul 11, 2006 | 06:21 PM
  #25
Sport Side's Avatar
Haven't been able to get to it yet. My flex-a-lite controller for the fans took a crap and the motor keeps wanting to run hot. I just stuck a new thermostat in with the BB mod and I'm just about to leave to go pick up my Flex-a-lite controller... Had it fixed.
I did however start tuning with HP Tuners... It's a drag because I don't have RTT with it yet, but I was able to get it to fire up on its own without playing with the gas. It's in SD for right now.
I'll keep this thread UTD... Videos real soon btw.
Old Jul 11, 2006 | 06:30 PM
  #26
Sport Side's Avatar
I have a bad tapping with my ED C cam. Its calmed down a bit but its still there. Im buying a set of 7.425" Pushrods from another member and see if it goes away.
Base circles are something like 1.4375. These are small block chevy lobe's actually, not Ed's. Call me crazy but, I'm using the stock push rods. Ran some calculations and it required .0075 longer rods. Seeing as I'm doing heads next, I didn't feel like wasting another 100 bucks when I have to buy a new set here in a month or two. I also talked to a few guys running stock push rods on aftermarket cams and they said they've had no problems.... Wish me luck??? But, I'm sure we could find some guys who have bent a few push rods or two, and counter that. We'll see.
Old Jul 11, 2006 | 06:48 PM
  #27
Sport Side's Avatar
Putfile video was added to the first post. Just a quick idle clip.
Old Jul 13, 2006 | 03:25 PM
  #28
blk_blazer00's Avatar
Kyle, truck sounds mean man. I cant wait to hear it in person this weekend. Sucks you're having problems already, but knowing you they will go away soon. have you decided if you are going to do the heads or just run with the cam only?
Old Jul 13, 2006 | 04:27 PM
  #29
1slow01Z71's Avatar
what headers are you running?
check the rockers...again...
Old Jul 13, 2006 | 04:35 PM
  #30
bodyman's Avatar
Default WHAT Do I Buy?????
I Have A 02 Gmc Sierra.v8 5.3l I Want To Get More Horse Or Power From It.what Are Some Of The Add Ons? My Friend Told Me To Buy A Cam And Heads ( Ls6 )? Don't Know!!!! I Don't Have That Much Money Right Now....
