102mm TB to nnbs mani w/ adapter plate?
Old Nov 25, 2016 | 02:16 PM
slvrram's Avatar
Default 102mm TB to nnbs mani w/ adapter plate?
Anybody ever tried to fit a 102mm throttle body on a NNBS manifold with an adapter plate like:
LS 4 Bolt Thottle Body Adapter - 92mm Intake Manifold to 102mm Throttle Body
The only info I've seen so far is some guy bolting a SD 102mm TB to a nnbs manifold and stated it fit without an adapter. I can imagine there was a huge difference in matching the rear of the tb to the front of the manifold.
This thread is completely for mechanics of the idea. I realize that the TB is way too big for anything a nnbs manifold would be sitting on.
Old Nov 25, 2016 | 03:45 PM
BlackGMC's Avatar
Resident Retard
I used the same adapter to put a 102mm on my supercharger
Old Nov 25, 2016 | 06:54 PM
slvrram's Avatar
So I guess in theory, given what you said, this will work. I assume your blower unit was machined to accept the stock throttle body?
Old Nov 26, 2016 | 10:10 AM
10 Second Club
I have a 92mm on my NNBS intake, it required me to open up the TB opening on the manifold. I don't see a 102mm fitting without an adapter or some mods to the intake.
Old Nov 27, 2016 | 01:48 AM
slvrram's Avatar
That's what I'm working towards. Thank you. How much material did you have to remove? Any pictures?
Old Nov 27, 2016 | 07:56 AM
10 Second Club
I didn't take any pictures, was in a rush to get it assembled. If had to guess, around an 1/8 inch was removed.
Old Nov 28, 2016 | 02:00 AM
slvrram's Avatar
Excellent. Thank you for the info.
