1000 rwhp turbo build question
Old May 21, 2016 | 01:34 AM
silveradodaniel's Avatar
Registered User
Default 1000 rwhp turbo build question
Hey everyone this is my first post.. I've been wanting to build a street truck with 1000 rwhp... Here's my idea... 6.0 ls2 lq4, heads, turbo cam, intake manifold, turbo kit (25-30lbs), built 4l80e, upgraded driveshaft and rear end.. My questions are, Is all this necessary for that amount of power? Will the motor hold that amount of power with those upgrades?
Someone tell me if this sounds right?
Old May 21, 2016 | 01:46 AM
07NBSChevy's Avatar
For 1000 RWHP you will need alot more than that, a complete blueprinted engine, o-ringed block and heads, forged internals, tig welded custom intake manifold, Serious injectors, custom fuel system, a big turbo, a built rear axle, A 4l80e from a reputable builder.
What is your budget? what is the purpose of the truck? Why 1,000HP?
You may need to set aside $25,000+ for this build.
Old May 21, 2016 | 02:05 AM
Blown06's Avatar
8 Second Truck Club
If you want a streetable engine capable of 1000 rwhp........the engine alone will cost 25,000.
...when I say "streetable", I mean that the can run around on the 1000 rwhp tune and not be afraid to beat on it.
1000 rwhp one-hit wonders are easy........but far from reliable.
Old May 21, 2016 | 08:41 AM
zero2sixT's Avatar
That doesn't take a $25k engine. With a total $25k budget I could put down 1k to the wheels and then drive it to Canada and back.
Old May 21, 2016 | 09:33 AM
Jake75's Avatar
As long as you aren't using the 1k hp on the way up there and back.
Old May 21, 2016 | 09:36 AM
03sierraslt's Avatar
That right there is a big part of the equation.
Old May 21, 2016 | 12:16 PM
zero2sixT's Avatar
Lol wow y'all are crazy to think you need a budget like that.
What is the build list for this necessary $25k engine?
Old May 21, 2016 | 12:25 PM
Jake75's Avatar
heads/cam/stall lq9, tbss intake, udp, efans
Old May 21, 2016 | 12:44 PM
I think 25K is a bit much but a stock motor isn't going to like that HP level for along time. Making 1/4m passes is one thing but something that is routinely going to be beat and be reliable then time for some good parts. Depends the combo and fuel. Also how fast you spin it is going to come into play. I would like to think my new motor will handle that without issue and it wasn't 25k. Also, a turbo setup is easier on the motor then a supercharged setup. The blower puts a large load on the crank so that will tie up some money to address that issue.
When it comes to high rpm a blower will really try to flex the crank do to the loading off of the front. Some also say at high RPM the back pressure of a turbo setup helps the rods live longer at higher RPM, I get the logic but don't know how much it really factors in.
I wanted mine to handle 7k rpm and 18psi or more so given that its a blower and not a turbo I put some money into the bottom end. Would my stock 6.0 do that? Ya most likely, but for how long is the question. I had it to 16psi and 6700 numerous times but didn't really get a warm and fuzzy feeling about it.
Old May 21, 2016 | 02:05 PM
GMCtrk's Avatar
Personally, I'd say 1/4 mile runs are far more taxing than using 1000 hp on the street. Think about it, on a 1/4 mile run you are flat out for 10 seconds or thereabouts. Where on the street are you putting down 1000 rwhp for 10 seconds? Unless you are doing serious street racing, most hits on the street are a couple seconds at that power level.
