100 shot n20
Old Feb 11, 2004 | 04:57 PM
ZDEN's Avatar
Default 100 shot n20
could i buy just a 5177 kit, bolt it on and spray, or do i need to upgrade anything else
Old Feb 11, 2004 | 05:42 PM
BigKID's Avatar
That is basicly all my kit is. If you are still running platnium plugs, you will want to replace them with some plain ole copper plugs (i run ngk tr55) and tighten the gap on them between .050-.055. (mine are at .053). If you are planning on spraying alot step down one heat range to the tr6 @ .035. Since it is a dry kit, dont get the nozzle too close to the maf or you will freeze it and wigg your truck out. Also if you have autotap or anyother scan tool, you might want to check your O2s and knock retard to make sure your injectors are keeping up with the juice and not running lean.
Old Feb 11, 2004 | 05:59 PM
GoldenVelvet's Avatar
all you really need is the bottle, nozzle, pumming, electric and your in. The 5177 kit is VERY easy to use and install. I safly droped 1 sec with a 60 shot, and I am going to make it a 2 stage 120 shot now that I have a scan tool.
Old Feb 12, 2004 | 08:37 AM
Seeing Red Again's Avatar
Hey Golden, are you spraying that 60 shot out of the hole?
Old Feb 12, 2004 | 11:43 PM
ZDEN's Avatar
thanks guys!!
natejk
Nov 15, 2016 08:05 AM
twake_410
Apr 14, 2016 09:58 PM
Velocity1
Oct 2, 2015 08:01 AM
Slammed silverado
Sep 28, 2015 06:14 PM
