1/4 mile performance?
Old Mar 7, 2007 | 03:54 PM
TXsilverado's Avatar
Originally Posted by Torque_Wrench
No...I meant 103. The last time I looked at the time slip ( Saturday evening) it said either 102 or 103. I was happy with that.
you gotta either have the time wrong or the mph wrong or you lost some MAJOR traction. i dont trap 103 running low 13's/hopefully high 12's.
Old Mar 7, 2007 | 03:59 PM
durty's Avatar
well they are already on the truck...so if they arent hurting anything we might as well leave the shorties on it...he has a nitrous kit for the truck...only gonna spray it with a 75 shot...so we could just drill into the spacer and put the nozzle there?...
he is wanting to do a remote mount turbo on the truck to...but we might just end up mounting it up front anyway...dont have to spend 200$ on a remote oil pump
Old Mar 7, 2007 | 04:07 PM
I had some spin on that pass (which was my 3rd pass) but nothing like the wheel spin I had on my first pass.
Old Mar 7, 2007 | 04:08 PM
Drill into the side of the spacer (be careful not to crack it) and fab your nitrous nozzle into that spacer. It's not like having a TNT Plate Kit but it works pretty well for what I did wiht them.
Old Mar 7, 2007 | 04:16 PM
Tan327's Avatar
I'd guess the 22's and 80E together are easily adding 1 second to your 1/4 mile time. A built 60E could do the job with that setup..
Old Mar 7, 2007 | 04:50 PM
durty's Avatar
he picked up the 6.0/4l80 for cheap...1000 for complete motor,tranny and harness. bought it from a local rebuilder shop, has 35k miles on it outta an 04 Express van.
next time it goes to the track its gonna have some smaller wheels on the back, he has been talking about puttin a built th350 in it with a big convertor.
Old Mar 11, 2007 | 01:29 PM
hog's Avatar
hog
I agree 103 mph from a high 14 second run??? Somethings fishy there. My best trap speed was 94 mph, but is usually aroun 90-91mph.
When I raced a Ford Lightning, it ran a 14.1 @99 mph to my 14.9@92 mph. And yous ay you are running 103 mph trap with a 4.8 with no power adder, or even a cam??
teh only explaination is a serious lack of traction. But even then.
peace
Hog
Old Mar 11, 2007 | 01:40 PM
TravisH's Avatar
hahaha there is no way you ran a 103 trap with that truck, unless you are seriously hiding something and you cant drive at all. haha I would say around 94 mph is believable.
back to topic...
A Th350 would not be the right tranny to put in that truck. The 80e robs a little to much power for what the truck is probably making and I would say that a well built 60e, like the ones offered by our site sponsor, FLT, would be a good choice. That along with a 3000 rpm converter and he should a have it running well into the 13's, mabye high 12's with slicks.
Old Mar 11, 2007 | 02:20 PM
nightrunner's Avatar
Mr. Obvious
um if he doesnt have some kind of tuning, he wont have a higher trap speed than 98mph, and he's leaving a lot on the table
Old Mar 11, 2007 | 02:24 PM
hog's Avatar
hog
back to topic...
The F-body gang with their 700r4 trans(same ratios as 4l60,60e, 65e and 70e) usually drop their ET by 3-4 tenths because the thm350 is more effecient than the 700, 60,60e,65e,70e transmissions, and also due to teh closer ratios of the thm350.
I might use a thm is a track only truck, but for a driver I would go 4l80e. Based on gear ratios alone, teh thm 200r4 trans form the Turbo 6's (GN, GNX, Turbo T) are the best.
2.74:1 1st, 1.71 2nd, 1:1 3rd and a deep 0.67:1 OD.
If big power is in the future, or if yu constantly beat on teh truck, the 80e should be used, if you drive on the more conservative side and dont plan on big power, a nice FLT 60e or 65e will work nicely with a nice stall converter to keep the large shift extension to a minimum due to teh large ratio spread of teh 60e type trans.
I wish the 80e had a higher OD gear, like .65:1 or something for better cruising. I do understand why GM decided on teh lower OD gear in teh 80e, simply because this trans was only offered in 3/4 ton trucks, save for teh 454SS and a few others. GM didnt want the crusie RPMs too low when folks are towing loads in OD.
peace
Hog
