07 LQ4 swap. Vids and prices inside.
I recently finished swapping an 07 LQ4 into my 02 Silverado. I couldn't find a list of prices or parts, I am posting what I did. I replaced anything that had a gasket or was emmissions related as preventative maintenance.
2007 LQ4 from a 2500HD - $1100 shipped
Motor mount -Anchor 2909 - $27.89ea
Spark plug - AC Delco 41-110 - $6.99ea 2 needed
Plug wired -AC Delco 9748HH - $46.79 (rockauto price)
O2 Sensor - Bosch 13193 (Canadian built vehicle) - $49.79ea 4 needed
Waterpump gasket - Felpro 35635 $5.51ea 2 needed
Intake Manifold gasket - Felpro MS92211 $30.89 set
Exhaust flange gasket, left side - Felpro 61074 $4.03
Exhaust flange gasket, right side - Felpro 61089 $3.74
Fuel Injector O ring, Upper - ES71192 $3.57 pk of 4. 2 packs needed
Fuel Injector O ring, Lower - ES71190 $3.70 pk of 4. 2 packs needed
Fuel Rail O ring kit - AC Delco 17113552 - $22.79
Oil Filter - Mobil 1 M1-113 - $12.99
Antifreeze - Prestone Dex-Cool 50/50 - $12.00ea
Distilled water,1gal - Wal-mart brand - $.98
Extras
Paper towel 8 pk - Wal-Mart - $6.84
Simple Green degreaser $5.96
Dielectric grease In tool box already
Electrical tape In tool box already
I did have to change the oil pressure switch from the 07 motor back to the 02 style. The style used in 2002 had a single wire connector on the wiring harness. On the 2007 LQ4,it had changed to a 3 wire connector. Not realizing this until after the motor was installed in the truck, I had to purchase an oil pressure switch socket. I also had to buy a new switch because I broke the original.
Oil pressure switch,single wire connector - BWD 18971415 - $40.19
Oil Pressure switch socket, 1 1/16" base - Lisle 13250 $8.95
I am still using the 5.3 pcm because I cannot find the pcm with the 6.0 tune from Wheatley.
I will come back later to post the equipment list. And I'll post mpg averages on the new motor.
http://www.youtube.com/watch?v=YkvBqJH946Q&NR=1
http://www.youtube.com/watch?v=z1rV051q9QE
http://www.youtube.com/watch?v=KjZ2omvfAhQ&NR=1
Extras
Superman09
Sep 25, 2015 05:55 AM
