06 Silverado 5.3 project
Old Aug 13, 2008 | 09:01 AM
Go5.3tt06's Avatar
Default 06 Silverado 5.3 project
Hello. Is somebody who can give me some good advice about my truck project. The reason I wonder if I can run with my stock bottom of 5.3 engine. But all my plan is-
210/218 Cam bec it is ok for tow my jeep or 4 wheeler sometimes. Or need to get a little bigger cam?
LS6 Yellow valvesprings
7/16 pushrod to find correct fit for aftermarket cam
Yank Highstall converter TT3000
Shift kit (might to get fully builder El60E probably El65E From finishline.com
I wonder if I could run single front mount turbo and run big intercooler. Will make alot power. What the horsepower can go 400-600? What size of injector needs to be. Do I need to run 255LPH fuel pump correct? And maybe run nitrous also wet or dry kit still not sure which one. Do you know Parish? What kind nitrous does he run wet or dry kit? I hope this thread correct to post. Or do I need to post on Forced Induction THREAD? Please let me know. Remind you if you not understand my grammar. Please tell me. I will try to explain clear since I am deaf. Thanks yall.
Luke
Old Aug 13, 2008 | 04:29 PM
Go5.3tt06's Avatar
Is everybody able read my thread?
Old Aug 13, 2008 | 11:49 PM
SBTork's Avatar
I think you're in the right area for posting this question. I don't have a lot of helpful info/advice for you. If you're looking to contact Parish, try PMing him, he's on here from time to time. Maybe try nelson performance, he's big in turbo truck applications. It sounds like you have some good ideas, welcome to the site.
Old Aug 14, 2008 | 01:03 AM
95 bright teal's Avatar
Looks like your headed in the right direction, and you could post in forced induction to get more traffic
If you can afford it a built 65E would be a good route, and what gears do you have?
have you ckecked with kbracing96 or trickturbo for their front mount setups? both are great options and they can help you set some goals, i bet with the right combo you could see 500hp to the wheels
Old Aug 15, 2008 | 04:35 PM
454SuperSport's Avatar
i'd use a zo6 (ls6) cam and yellow springs. along with a front mount turbo setup should easily make 400+ rwhp. go ahead and get a level 4 or 5 trans from finishline performance and a yank tt3000 should be fine. your gonna need atleast 60 lb. injectors, there was a guy on here selling some custom ones that were a direct replacement so you wouldn't have to change the pigtails and put spacers on the rails.
Old Aug 15, 2008 | 10:10 PM
Go5.3tt06's Avatar
Thank you for all info. I already got ahold some people with other thread. Everything is good!
Old Aug 15, 2008 | 10:11 PM
Go5.3tt06's Avatar
Probably run with 3.90 bec i getting 20" wheels.
chopperloco
Jul 10, 2016 10:45 PM
zo6freak
14
Oct 18, 2015 06:43 PM
B.love18
Sep 21, 2015 08:31 PM
04450r
Jul 24, 2015 01:58 AM
samg430
Jul 20, 2015 10:12 AM
