05 Tahoe cylinder 1 misfire need some help please
Old Oct 31, 2016 | 12:16 AM
03 silverado's Avatar
Default 05 Tahoe cylinder 1 misfire need some help please
Ok so I'm working on a 05 Chevy Tahoe 5.3 liter, had a bad lifter on cylinder 1 so I pulled the head, replaced lifter. The cam lobe was wore just a little bit but nothing to major so I decided to leave it in before putting in a new one. Now what I'm wondering is if it was wore out enough to cause the valve to not open all the way which in turn would cause a misfire. I switched spark plugs, coils, injectors an no matter what still had a misfire on cylinder 1. Anybody have any insight to help me out?
Old Oct 31, 2016 | 12:26 AM
FFDP's Avatar
Compression test it yet?
Try lowering the spark gap if they are set higher than .040.
Maybe there is still a vacuum leak too.
Old Oct 31, 2016 | 12:46 AM
Forgot to mention I'll be doing a compression check on the morning, I don't have one so gonna borrow a buddy's. I put a new spark plug in there an gapped it to .35 an I double checked on the vacuum leak as well an all was good
Atomic's Avatar
I have a gauge for that
How bad of a misfire is it? Sure its not a burned wire or cracked plug?
Old Oct 31, 2016 | 12:54 AM
Not horrible but it's always there, not lik it comes an goes. An no I tried 3 different plugs an swapped 3 different wires in an it's still the same thing
Old Oct 31, 2016 | 01:00 PM
Did a Compression test an got 165. I'll swap in a another stock cam an see if that fixes it
Old Nov 1, 2016 | 01:06 AM
Well swapped cams an seems to run fine now. I'll take it for a good test drive tomorrow to make sure but I think it solved my problem
