05 Tahoe cylinder 1 misfire need some help please
Ok so I'm working on a 05 Chevy Tahoe 5.3 liter, had a bad lifter on cylinder 1 so I pulled the head, replaced lifter. The cam lobe was wore just a little bit but nothing to major so I decided to leave it in before putting in a new one. Now what I'm wondering is if it was wore out enough to cause the valve to not open all the way which in turn would cause a misfire. I switched spark plugs, coils, injectors an no matter what still had a misfire on cylinder 1. Anybody have any insight to help me out?
Forgot to mention I'll be doing a compression check on the morning, I don't have one so gonna borrow a buddy's. I put a new spark plug in there an gapped it to .35 an I double checked on the vacuum leak as well an all was good
