'05 Sierra Denali Magnaflow exhaust?
Old Jan 14, 2009 | 03:57 PM
1 Clean WS6's Avatar
Default '05 Sierra Denali Magnaflow exhaust?
Hey all!
I'm in the market for getting a cat-back for my '05 SD. I've had a bit of trouble finding a company that makes a system for my truck. The 6.0L (LQ9), crew cab and 5'8" bed combo seems to be a bit of an oddball.
I found a system by Magnaflow marketed for the 1500HD 6.0L (LQ4) with the part # 15782. It is described as such:
"V8 6.0L Crew Cab, Short Bed 5 x 11 x 22 in. Muffler, 3 in./4 in. Tubing, 4 in. Tip; SINGLE REAR SIDE EXIT".
Will this system work for my truck??
Pic...
Many thanks for your help!
Mike
Old Jan 14, 2009 | 10:03 PM
lq9crew's Avatar
Easier to search for a catback for a Silverado SS. They used the same setup as your truck and mine.
The one above is not a bolt on for your truck. It will be too long among other things.
Old Jan 14, 2009 | 10:44 PM
BigCountryx's Avatar
I would bet it slides right in... most catbacks for these truck are prety interchangeable as long as it's the same L motor. For example I have that same tailpipe from that kit with an Aero STX640 muffler and it fell right into place. Good luck.
Old Jan 14, 2009 | 11:21 PM
ForcedTQ's Avatar
You'll want to check the inlet size on the existing system to the muffler. I believe they are dual 2.5" not dual 3". I picked up the Magnaflow system in my signature which is designed for the SS and the Denali's. I ended up purchasing the cat pipes off of an SS so that I could run the whole thing like OEM since I was installing long tubes, but for you it would bolt right up. If you want a single rear exit exhaust this one in my sig is pretty damn nice.
Here's a link to my exhaust build https://www.performancetrucks.net/fo...d.php?t=403537.
Old Jan 15, 2009 | 08:56 AM
tiffo60's Avatar
Why not just go to a muffler shop and get a custom setup? You will more than likely save a couple of hundred bucks and have exactly what you want.
I did a true dual magnaflow set up on my Denali and stainless tips and seems like it was around 400 or so
gnasty1521
35
Nov 19, 2015 11:42 PM
chacho44
Aug 3, 2015 04:07 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
chacho44
14
Jul 25, 2015 01:47 PM
Denali man
Jul 19, 2015 03:52 PM
