05 E-Fans - Voltage Drop
Old 01-11-2005, 05:28 PM
  #21
KySilverado's Avatar
Originally Posted by CRAZYCUTER4.8
I could not paste everthing, but there is a voltage control module that is regulating voltage, the output in 05 is greater as well
Great info.... all I can do it try the larger amp alternator.....unless a 05 PCM and EPM could be swapped to an 03 model I assumed the 05 PCM would have dual fan control via two outputs. My HP tuners has the option to control them individually. Believe the F-bodies have had dual fan control in their PCM's for awhile.
Old 01-11-2005, 07:11 PM
  #22
VortechC5's Avatar
Thanks, Mort!
Originally Posted by Mort
K65 = Alternator, 105 amps
K68 = Alternator, 105 amps | 2003
KG3 = Alternator, 145 amps | 1500HD
Old 01-21-2005, 04:28 AM
  #23
Z1500's Avatar
Anybody know if the the new Nelson harness came out? Does Nelson have a website?
Kevin
Old 01-21-2005, 04:49 AM
  #24
therock's Avatar
Kevin
nelsonperformance.com
Old 01-21-2005, 08:08 AM
  #25
creederado's Avatar
I bought a 3 relay Harness from Allen In November, Nice piece. makes it real easy. I'm waiting on some 2005 fans ordered from My dealer for the 99. I already have the 34" 6.0l radiator and 145 amp alt. I can't comment on how they perform yet but does anyone know what "changes" were made to Allen's harness for the 05 fans? I don't for see a problem once you get the 145 amp alt. I may wrong.
I just emailed Allen for another harness and tune for my 03. I'm a very satisified customer.
Old 01-21-2005, 04:52 PM
  #26
I assume just new connectors for the fan motors. I installed my set with the LS1 version from Nelson. Had to turn the connectors around to get the fans to turn the right direction and to fit the motors. Only problem with that is they don't not snap lock in.
Old 01-30-2005, 10:08 PM
  #27
SmokingWS6's Avatar
Thats normal operation. Fbodys will dim a bit at idle with the fans on high. Best advice as mentioned is to upgrade to the OE 145 amp alternator found on hd's and suv's.
vmaxpro
09-28-2015 11:10 AM
twake_410
09-25-2015 10:09 PM
lycominghunter
26
09-25-2015 07:50 AM
Boyes50
09-08-2015 12:06 PM
muncie21
09-07-2015 09:55 PM
Quick Reply: 05 E-Fans - Voltage Drop
