05 E fan questions
Old Nov 27, 2005 | 12:20 PM
Ron's5.3's Avatar
Default 05 E fan questions
I have read a bunch of posts and I am trying to get some input on a temperature setting for the e fan turn on temp with a stock thermostat on a 6.0 silverado 2500ld. I am going to try to run it with a threaded thermostatic switch in the block for now. So it will have a set turn on point. Later in time will look at a tune.
Also, since the fans have two blade styles, which blade should be on for the A/C only.
Old Nov 27, 2005 | 07:52 PM
therock's Avatar
Default 05 5.3 Info?
This is for 05 5.3 efans. It will get you close.
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
