04 and up fuel system options???
Old Sep 18, 2006 | 04:13 PM
2004SSS's Avatar
so has anyone done dual intank pumps on a returnless?? also what 60lber are you running? where did you get them??
Old Sep 18, 2006 | 11:54 PM
moregrip's Avatar
what a rush!
something like this, not necessarily the whole thing, but the maybe using the metal basket portion and fitting it to the upper portion of our setups
Old Sep 19, 2006 | 12:10 AM
2004SSS's Avatar
that is probably for a return system huh? looks nice , id love to use that.
Old Sep 19, 2006 | 04:07 AM
dewmanshu's Avatar
Moderately Differentiated
grippy that would certainly be the ticket. is that a project piece or something that is sold. And as chase says...return?
Old Sep 19, 2006 | 07:01 AM
FlaBouy's Avatar
Originally Posted by dewmanshu
this sounds like the common advice around, the only thing is I know people do it, but it seems being on a returnless system and getting 500hp out of the 42lber's is harder. Not that people aren't doing it, just moving up in injector is probably a real good idea. Soooo I'd change it up a little, once you hit 450hp-put on your mod list injectors if you plan to go after more horses. especially 500+.
I ran the 42# in my truck and was seeing 120% duty cycles at 403 rwhp... I added the 60# injectors and heads... Now at 500+ RWHP I am seeing 65-68% duty cycles @ 55 psi. I run the 255 lph Walbro intank.... No issues so far and I have run this for nearly a year at 11.8 afr at 5800 rpm seeing 185 kPA logged through hp tuners... Can't answer yet for 600+ rwhp... yet....
Old Sep 19, 2006 | 07:12 AM
dewmanshu's Avatar
well there you go. Upgrading injectors- again an advisable item.
Old Sep 19, 2006 | 10:32 AM
Blown06's Avatar
8 Second Truck Club
hey moregrip,
what is are pics from?
hurry, that looks bad ***.
Old Oct 29, 2006 | 11:21 PM
2004SSS's Avatar
so moregrip where is that dual intank set up from?
Old Oct 29, 2006 | 11:33 PM
Keith's Avatar
How hard would it be for you guys to set up a return style system? I mean the F-body guys do it.
Old Nov 6, 2006 | 12:42 AM
2004SSS's Avatar
c;mon guys somehas to have done this??
