04 gto ls1 or 01 hd 6.0
Old Oct 2, 2007 | 09:00 PM
RED2K's Avatar
Default 04 gto ls1 or 01 hd 6.0
i have been shopping for a new motor to hurry up and throw in my truck to get it back on the road. I found a long block 5.7 out of a 04 gto with 20k miles for $1500 and i found a 01 6.0 complete pull out of a 4x4 2500 hd. for $1350 the truck was wrecked. It was also used as a work truck. The 5.7 was in a gto that got a 6.0 built and stuffed. What would you guys go for? If i go for the 5.7 will my 5.3 injectors work for now? will everything like my water pump and crank pulley work and blah blah blah? i know my intake and what not will swap right over. just wanted some of you guys input. thanks
Old Oct 2, 2007 | 09:05 PM
99Silverado5.3's Avatar
Everything will swap over on either.
What is the mileage on the 6.0L? Also, are you considering going to an even bigger motor later down the road? It's a coin flip to me.
Old Oct 2, 2007 | 09:07 PM
RED2K's Avatar
77k sorry
Old Oct 3, 2007 | 01:20 AM
If you want to do a bigger motor later down the road I'd go 6L, if not I'd go with the ls1. Can't go wrong with either one IMO.
Old Oct 3, 2007 | 02:56 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Go with the 6.0 iron block
Old Oct 3, 2007 | 06:45 PM
RED2K's Avatar
its just gonna get a cam and thats about it
Old Oct 3, 2007 | 06:57 PM
ap2002's Avatar
dont mess around and go with the LS1..... it has less miles, newer and it will run very similar to the 6.0, the 6.0 is too old and more miles... plus the LS1 is lighter, which will almost makeup for the difference..
and yes everything off you truck will bolt right up to the LS1 block for sure.... good luck on the swap and let us know...
Old Oct 3, 2007 | 07:16 PM
RED2K's Avatar
thanks
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trxmxzx
Sep 29, 2015 07:42 AM
sTNT971
Sep 26, 2015 04:22 PM
