04 E Fan nelson harness ?'s
Old Oct 10, 2005 | 02:40 PM
98TAauto's Avatar
Default 04 E Fan nelson harness ?'s
Hey everyone... just got some ls1 fans and the nelson harness from a friend for my 04 5.3. I have a few questions. Will the fans work without a toggle switch or do i have to get nelson to edit my pcm or find someone else with edit/hp tuners to make the fans work? I thought I read where they worked at low speed with the factory pcm? Im new to this so any info on those fans/harness for a 04 please lemme know. I just didnt wanna have to toggle my fans off and on.. espically if someone else drives my truck and they forget to toggle it on
Old Oct 10, 2005 | 05:47 PM
CHarris's Avatar
The nelson harness has relays and are made to work without a switch. But you can run one temporarily as the only means of turning them on. You can alos retain a toggle and PCM control later on. The best bet is to do a switch and hurry and get the PCM changes made so you don't have to worry about forgetting (say you've had a beer or four...) or loaning the truck to someone and they forget to turn the fans on. Manual fans are nice when you want them but a PIA 85% of the time.
Old Oct 10, 2005 | 05:52 PM
FarmerBeau's Avatar
Sexy Party Mod
Definately gonna need a tune, otherwise its gonna be a PITA!
Old Oct 10, 2005 | 07:09 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, if you don't want to have to do it manually via a switch, the PCM has to be tuned for it.
Old Oct 10, 2005 | 09:54 PM
98TAauto's Avatar
well dang....
can hptuners do it if so, what needs to be done?
Thanks for the info btw
Old Oct 11, 2005 | 08:59 AM
BigBlackAv's Avatar
Also, is there a way for for the pcm to to call for high speed w/ out the ac being on....and does anyone have a wiring diagram that I can use to modify my set and make a switch for manual on low, manual on high, manual off, and auto.
Old Oct 11, 2005 | 09:01 AM
BigBlackAv's Avatar
Maybe I should controll the ls1 fans w/ my FAL controller.
Old Oct 11, 2005 | 09:37 AM
TXsilverado's Avatar
throw your FAL controler away IMO.
Old Oct 11, 2005 | 12:59 PM
Fogle07's Avatar
i got my fans to come on the entire time the truck is running and i also have a toggle switch if i want to turn them off
Old Oct 11, 2005 | 03:28 PM
METALMULISHA777's Avatar
yeah just use the nelson harness thats all u need mines never been over 180 i see no need to turn em on with a switch.. i mean if its really hot your prob gonna have the ac on which turns 1 fan on.. and when it hits the temp thats 2 on hi which cools it down faast IMO
