03 cooling issues - advise please
Old Aug 26, 2005 | 07:38 PM
Default 03 cooling issues - advise please
2003 - 5.3 - with 7,100 miles -
- installed a 180F stat
also have a electric gauge in the RR of the RH head
so I know the auto meter gauge is accurate.
Also an underdrive pulley
here is my issue
at 70 mph on the highway - gauge reads just a tick under 195 F
as soon as you get into stop and go traffic
heats right up fast to 210 and stays there
between lights.... it might sit between 195 and 210
I want to stay cooler than it is.
possible solutions
1. remove the underdrive pulley and see what the temps are
2. install a 6.0 radiator (which is slightly larger) - keep the underdrive pulley
and see what the temps are.
3. dont worry about it.
what do you think - thanks
Old Aug 26, 2005 | 08:59 PM
one03sierra's Avatar
Formerly one92rs
Talking
3. i 180 therm is going to run about 195 anyway. did you bleed the system? 160 is going to run 180.
Old Aug 26, 2005 | 09:03 PM
TXsilverado's Avatar
i wouldnt wory about it. 210 isnt bad for your motor.
Old Aug 27, 2005 | 12:18 AM
bled well - it has been in there for a year plus
Might just have to swap out for a 160 and re-prog my ecm.
Old Aug 27, 2005 | 08:13 AM
litreddevil's Avatar
Banned
I Would Not Worry Just To Let You Know A Friend Of Mine Put A 98 5.7 Vette Motor And Everything Fine Then Put 3.73 Gears And Ud Pulley And His Truck Started Running Hotter Than Before.then He Wanted To Remove The Ud Pulley Instead Of Installing A 160*,then Started Running Fine Again.
Idryfly5
Sep 2, 2022 08:55 PM
99bluefirebird
Sep 17, 2015 08:05 PM
MA$TER_E
Sep 9, 2015 03:14 PM
